+ Reply to Thread
Page 1 of 9 123456789 LastLast
Results 1 to 10 of 90
Thread: Kenwood Nav input & touchscreen output
    Mar 2004
    Los Angles
    A question before I get out an o scope has anyone sucessfuly used a kenwood nav RGB input for video?
    A kenwood tech support guy told me it is a standard RGB input 600x800 Fv=15khz Fh=60hz
    does anyone have any info on the kenwood Nav data buss?
    here are some roumors from the same tech guy
    the kenwood nav unit hardware is an Industrial PC using standard hardware
    ( this is not realy a roumor it is fact industry insiders like me have known this for years the Alpine has standard IPC hardware as well and the Pioneer is said to be 60% IPC ) the O.S. he heard is said to be a version of windows ce but he belives it is most likly a version of Linux witch is what I have been told as well
    thinkin what I am thinkin
    If the hardware is standard pc hardware than maybe we can just plug the data into a USB or SERIAL port and load drivers I say this because it is possable that the data is one way I have not been able think of a reason why the nav would need to send data back to the head unit if the data is one way then why wouldn't kenwood use off the shelf hardware and software
    it saves them time and money
    what do you think
    Elsewhere
    Good luck.
    How about the Wiki?
    Sep 2005
    Kenwood's "RGB" is used for data such as touchscreen and nav controls. The actual video is sent through a composite video cable. A Kenwood NAV unit has an RGB (kinda looks like an S-Video or PS-2 cable) AND a composite video cable sent to the lcd head unit.
    just fyi...
    Mar 2004
    Los Angles
    bagwellfive your wrong and seem to be uneducated about the standards and hardware you are speeking of
    the kenwood nav does have a RGB output and the kenwood monitors also have an RGB input the nav also does have a composite video out for use with a composite monitor if you are trying to save a few bucks
    RGB is short for RGBVH witch means red green blue vertical sync and horizontal sync there are many variants of RGB pc VGA is one of them no data or control signals can be sent through an RGB signal
    I am posting this thread to see if anyone knows if I can just wire up a custom cable or if I will need a converter to convert from one RGB standard to another I am asking to save time and not have to do a lot of testing to find out
    the cable you say kinda looks like an S-Video or PS-2 cable is a custom cable with a standard 13 pin din plug at both ends the cable has wires for RGBVH, analog audio, power up signal, common ground, and control data, and a few extra unused wires
    Just FYI...
    Sep 2005
    faakoff w/that 'uneducated' bull****.
    that 13-pin data din plug has been used for years as for things like CD changers. The only thing that remotely resembles that pinout while carrying video signals was made for old-school Atari's. Having barked up this tree before, I've found several different pinout diagrams that may be relevant.
    1. Audio
    2. -
    3. -
    4. -
    5. -
    6. Green
    7. Red
    8. GND (Audio)
    9. H-sync
    10. Blue
    11. -
    12. V-sync
    13. GND (Video)
    and
    1 AO Audio Out
    2 CVIDEO Composite Video
    3 CS Clock Select
    4 MD Monochrome Detect / Clock In
    5 AI Audio In
    6 G Green
    7 R Red
    8 +12V +12 VDC (520ST has GND)
    9 HSYNC Horizontal Sync
    10 B Blue
    11 MVIDEO Monochrome Video
    12 VSYNC Vertical Sync
    13 GND Ground
    the most relevant to your application would be the first of two pinout diagrams since the second dwells into proprietary atari functions.
    hope this helps.
    Mar 2004
    Los Angles
    porgress at last
    I got VGA video on a Kenwood DDX 7015
    tonight I got a Kenwood nav cable witch I promptly cut up
    here's what I learned so far
    blue = +5v power up signal
    gray = seems to be same as blue
    purple = +5v nav turn on signal
    orange & pink wires seem to be data they spike to .2 volts DC when the screen is touched I need to do some testing with an O scope to be sure
    there are two gray sheilded cables inside the nav cable the small one has 2 wires in side
    white = I think is audio left +
    red = I think is audio right +
    sheild = ground
    the bigger shielded cable is the RGB signal cable
    yellow = green
    white = blue
    red = red
    green = Fh
    shield = ground for all signals
    compatable Fh = 60hz only
    tested at 640x480 32 bit true color 60hz
    there is no vertical sync input wire
    the video needs some kind of converter I am getting a double image and it is not centered at all but the small text was quite readable it was a little fuzzy but no more fuzzy than my old 7" VGA screen at 800x600 I think the fuz will go away after a little video scaling
    what you guys think
    I will mess around with it some more when I have some time
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    That's tight! I just installed a Pioneer AVIC-88DVD. These nav units are definitely computers. My unit has a RISC processor and 64mb of ram. It even has a PCMCIA slot.
    The Pioneer RGB cable is 26pin and when connected to the Pioneer AVD-W6210 has a very sharp picture. The RGB cable carries video, audio and data (touchscreen and button input).
    You must have a small pile of cash lying around if you're tearing up your RGB cable. I know for Pioneer's there cables cost $75+,
    Jun 2004
    Los Angeles
    The DDX7015 is 480x234. Nearly all navigation system screens are like this (except for the new Eclipse Dual DIN AVX units and the Alpine IVA-D910).
    I'll be damned if you could get input from a computer to look half-decent...good luck and I want more pics!
    -HD
    Quote Originally Posted by port20
    sheild = ground
    yellow = green
    white = blue
    red = red
    green = Fh
    what you guys think
    Mar 2004
    Los Angles
    I don't have a lot of cash I am a mobile electronics installer so head units cables and amps are all dirt cheep for me I just have to ask for it sometimes I ask hard very hard!
    that is not true the older screens were the DDX7015's lcd has a native res of 600x800 all newer Kenwood nav screens are 600x800 but I have a feeling that the RGB video controller in it may only go as high as 640x480 I should know for sure in a few days
    Alpine has a HD screen comming out in a few months and kenwood will by next august there booth said to be 720p
+ Reply to Thread
  1. Kenwood KDC-6009 changer input
    By zap_b in forum General Hardware Discussion
    Last Post: 12-01-2005, 10:23 PM
  2. Kenwood Composite Input
    By alphadan in forum General Hardware Discussion
    Last Post: 10-24-2005, 03:53 PM
  3. Sound Input / Output / Interference
    By leesilk in forum General MP3Car Discussion
    Last Post: 06-01-2003, 12:47 AM
  4. Replies: 5
    Last Post: 08-20-2002, 09:29 PM
  5. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 02:49 AM
