Results 11 to 20 of 22
Thread: TH-868 Driving me crazy.
  1. #11
    Jul 2005
    Quote Originally Posted by mike-e-mon
    Sometimes it's the jokes that keep us going. Don't take it to serious.
    Mike
    Don't you mean "too" and not "to"? Gotcha.
  2. #12
    Jul 2005
    Now I have a nother problem. The monitor doesn't show up in the setup screen for calibration. When I plugged it in the usual add new hardware promp came up and I did just that. Then I installed the new software and it doesn't show at all. What to do, what to do.
  3. #13
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Why does it matter? The only thing that the OS should do is set resolution and refresh rate. A standard VGA resolution of 640x480 is all you need.
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
  4. #14
    Jul 2005
    Quote Originally Posted by psyrex
    -psyrex
    I understand that. The problem that I'm talking about is with the touchscreen software. There is a calibration with 4 point on the screen and to do it you need to chose the monitor in the activation window of the software . My monitor doesn't show up though. When I installed the software I think it was suposed to be done before hooking up the monitor then a reboot, then the monitor. I did it *** backwards though. How do get rid of the touchscreen in the harware device section so I can start over again. Also are any registry changes that need to be done in order to remove the device the right way so that when I reinstall it will work? I know I'm a big pain in the fu**ing *** right? My mother says the same ****. Thanks
  5. #15
    Low Bitrate mike-e-mon's Avatar
    Jun 2005
    Unplug the USB cable for TS.
    Uninstall the TS driver, using Add and Remove Programs in control panel.
    Restart computer.
    Install the TS driver.
    Plug in the USB cable for TS.
    Mike
    "Open your eyes, look within. Are you satisfied with the life you're living?"
    Bob Marley
  6. #16
    Jul 2005
    Restart computer.
    Mike
    That didn't work.
  7. #17
    Jun 2005
    Quote Originally Posted by UncleMike1
    That didn't work.
    Does the TS show up in device manager? Does the TS device have yellow or red dot indicating a problem with the driver install?
    Mike
    Bob Marley
  8. #18
    Jul 2005
    Mike
    No not at all. It look normal and says working properly.
  9. #19
    Jun 2005
    After uninstalling the drivers try this.
    http://www.mp3car.com/vbulletin/show...1&postcount=12
    Make sure NOT to check the box that says "Install PS/2 interface driver". Connect the USB plug for the TS after the TS software has been installed. Good luck.
    Mike
    Bob Marley
  10. #20
    Aug 2005
    Corinth, MS
    Did you every try what I said in that PM? Reformatting the harddrive and re-installing the correct way? Plugging in the touchscreen USB cord before installing the drivers will cause driver conflicts.
  1. Driving in Italy - An American View
    By Bugbyte in forum Off Topic
    Last Post: 11-14-2006, 07:50 PM
  2. Laptop driving me crazy.
    By UncleMike1 in forum LCD/Display
    Last Post: 09-07-2005, 12:13 AM
  3. This is driving me crazy
    By bobs987 in forum Power Supplies
    Last Post: 03-09-2005, 02:55 PM
  4. Usb Radio Driving Me Crazy
    By (6) in forum General Hardware Discussion
    Last Post: 12-09-2004, 04:04 AM
  5. Sound playback issue driving me crazy.
    By Arby in forum General Hardware Discussion
    Last Post: 05-09-2004, 09:35 PM
