Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Lilliput with permanent white screen of death
  1. #11
    Feb 2004
    Victoria, Texas
    It is a 7" lilliput. Probably a year old or so.
    I will try what studmonkey recommended.
    But who knows, I very well could of shorted it. I was moving it around a lot while it was on trying to find that perfect "sweet spot". Unfortuantly it just stopped workign at all. I know the cable is very sensitive, because It was when I had it working using the tooth pick trick. But now it is just non responsive, since I can move it all around any which way and in any direction.. and still only get a white screen.. i wouldnt be suprised if I fux0r'd something up.
    Thanks for all the comments so far much appreciated
  2. #12
    Feb 2004
    Victoria, Texas
    Alright so I tried what was recommended above and still nothing. Im pretty sure I might of messed up something.
    So my question(s):
    If I did indeed bust a trace or something by moving the ribbon cable around while the LCD was powered on, is there anything I can look for or do to fix it?
    If there isn't anything I can do, can I sell my lilli for parts or is it pretty much just trash?
    Are the new lilli's sold on the mp3car.com store better than the old ones (the one I have now is over 1.5 years old?)
    - Jared
  3. #13
    Oct 2004
    NY
    you can sell it for parts, only problem is you can't confirm which is bad, the lcd or the controller or posibally even both?.....I'd gamble its only the lcd, but theres no way to tell without having another of these to test each part... the touchscreen is probably fine at least....
  4. #14
    Feb 2004
    Victoria, Texas
    haha no the right side of the TS went out about 5 or 6 months ago.
    SO basically this pos isn't worth squat, but that is really what I figured
    How about those new Lillis @ the mp3car.com store? Are they better than the old generation?
  5. #15
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey dude u prolly fried it :-( if u decide to part it out leme know !! i might be comin to tx in a month or two to visit family so :-) maybe i can revive ur lilli lol
  6. #16
    Oct 2004
    NY
    I have a few older lilli's & there fine unless you screw them up
    sorry...
    I don't know if the new ones are "better"
  7. #17
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I know i'm coming into this late, but what has happened is you have fried the small square PCB on the back of the LCD, if you put the ribbon cable in at any sort of a angle you run the risk of frying it. Those controller PCB's are replaceable and if you can find someone with a busted screen you can swap them.
    But if your looking to get rid of anything, I can use it for the backlight upgrade project.
    肚子笑痛了
    S60 Install
  8. #18
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jcdillin
    Pictures man, pictures.
  9. #19
    May 2003
    Miami, FL
    Pictures of what?
    肚子笑痛了
    S60 Install
  10. #20
  1. Replies: 37
    Last Post: 03-19-2010, 02:08 PM
  2. Lilliput screen inside motorized unit?
    By JayKaye in forum LCD/Display
    Last Post: 09-29-2004, 02:14 PM
  3. Lilliput only uses a portion of the screen
    By gambit32 in forum LCD/Display
    Last Post: 09-06-2004, 01:11 AM
  4. Replies: 4
    Last Post: 09-01-2004, 02:02 AM
  5. Should the Lilliput screen be a little loose?
    By the_dude in forum LCD/Display
    Last Post: 05-05-2004, 09:12 PM
