Results 1 to 10 of 11
Thread: Lilliput losing calibration
    May 2004
    I use the Touchpad Configuration tool to calibrate the screen and that works fine for both the 4 point and the 25 point (advanced) calibration tools however shortly after I calibrate the screen it goes out of wack. I touch the screen and it response like a half inch to an inch away. What could be the reason behind this? Is my touchscreen going? If so, is there anyway to fix this?
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    What is wrong with you people.....this topic has been covered like hundred times in the past week!!!
    May 2004
    Quote Originally Posted by MaleBuffy
    I checked the past couple of day's posts and while yes there are SIMILAR topics, this one isn't the same as others. I am not having USB issues, I did not do any wiring. If you read my post, the touchscreen works. It has been ever since I got it 1 1/2 years ago. But all of a sudden I am getting this lose of calibration issue where sometimes a press on the screen will be right and sometimes it will be off by an inch or so.
    All I am trying to do here is get some help and don't want to deal with idiots like you who are so QUICK to bash people for posting what they think is a duplicate post. So what? So I posted something that someone else may have posted. And YES, I did a search and I didn't find anything exactly the same as my problem.
    So next time you read my question on a post, either reply with something intelligent to say or click BACK and go bother someone else with your meaningless rants.
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    You ever figure this out tmar? I have the same issue. It calibrates perfectly fine and works in RR etc but after a while it is WAAAY off and I have to recalibrate..
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    May 2004
    It ended up being a dying touch screen. I replaced the touch screen film and it worked fine after that. http://www.digitalww.com/ has reliable ones.
    Oct 2003
    Poland, OH
    :O Oh noes.. That's not what I wanted to hear..
    Weird that it works fine but seems to "forget" the calibration until I recalibrate it..
    Oct 2003
    Poland, OH
    I had this issue (like I posted above) and it seemed to correct itself shortly thereafter (I didn't do anything to fix it that I know of).. Now, it's happening again over a year later..
    Some days the touchscreen will work fine, some days it will work for a few minutes after recalibrating, and some days it will work just after rebooting..
    Any ideas? I find it hard to believe that it's a bad touchscreen because I was having the issue and then not having it for over a year..
    Jun 2007
    My screen is doing the same thing, except it occurs right after calibration.
    I want to say its a software driver malfunction because I ran it under linux and it works perfect but under windows it gets screwy.
    Im using the drivers from http://210.64.17.162/web20/eg/drivers.htm and the version 5.0.1.5310 from 2008/07/31 and under linux im using evtouch from the ubuntu repos
    Oct 2003
    Poland, OH
    Quote Originally Posted by Virac View Post
    It's very strange.. Some days I don't have any issue at all.. Some days it will work, then not work, then work all in the same car ride.. :S
    Jun 2007
    Mine does it consistently. Ive taken a volt meter to it. tried taking the lcd apart. The only other factor i could think of is ambient temperature but that should be negligable once the backlight turns on and starts puting out heat one would think
  1. lilliput calibration failed??
    By nomorspam in forum LCD/Display
    Last Post: 06-30-2005, 10:41 AM
  2. Lilliput often needs calibration
    By cyrix^ in forum LCD/Display
    Last Post: 06-10-2005, 03:53 PM
  3. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  4. Replies: 11
    Last Post: 11-15-2004, 09:30 AM
  5. Lilliput 4-point and 25-point calibration?
    By chris in nh in forum LCD/Display
    Last Post: 06-20-2004, 02:16 AM
