think it means accesoiries
you need to feed +12v on that wire too.
it is a signal wire to connect to let the thing only go on when your contact is on.
connect it to a +12v which is only present with your contact switched on.
I have a 5" LCD display from Parts Express and it has four lines coming out of it, they are: ACC, GND, BATT12V, and Stereo. I tried connecting the GND and BATT12V to the black and yellow lines from the computer (yes, the two next to eachother), however, the screen would not turn on. Do i need to connect the ACC to something to get this to work? And what is the ACC? Thank You
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
which 5" is this one? is it the one which folds up/down? if so, i can help you with that since i have it working just fine in my car. lemme know.
2004 F-150
Shuttle XPC, 80gig HD, Wireless Internet, DVD
"How piMP3d is your ride??"
Yeah i just got that LCD.
Here's what you gotta do:
The black one that says GND needs to run to your (-) battery terminal or an unpainted metal part of the body of your car. The red 12V line needs to run to the (+) terminal of your battery, or another POSITIVE power source (accessory power works if that's easier). The ACC line needs to run to a switched power source (one that turns on and off with the car, or the deck, or whatever). There's an ACC wire that runs into your deck, and if you have subs/amp, there's a wire that runs to those that has power when the radio is on. If those aren't easy, you can splice the (+) wire and have one splice run to 12V and the other go to a switch and then into ACC, or since this unit has the power switch on front, you could just have the (+) line run right to the ACC and PWR, as long as you turned off the screen yourself when you parked so that you didn't drain the batteries.
Mp3car setup on the way... it's gonna run like this:
5" TFT LCD running out of a 32 MB 4x AGP GeForce 256, on a 667 MHz Celeron and a 4.3GB Hard Drive, running linux and probably MS98 solely for the purposes of Diablo II.
Also a playstation 1, and my stereo:
2 Rockford Fosgate 360a2 (1 punch, 1 power) running 4 10" subs.
1 RF punch 120a2 running 2 Jensen 6x9s in boxes
Custom box (it looks cool. pics someday)
4 ga. & 8 ga. power
10 ga. speaker wire all around
16' RF shielded RCA
Pioneer 1100DEH (until I get a MP3car)
