Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Ordering replacement lilliput ribbon cable
  1. #11
  2. #12
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    negative ghost rider!
    I will ask in avionics if they are ordering anything. Will give em the money and pass it over. Might get a couple myself to see if i can shave the insulation off to turn them into xenarc cables!
    leave it with me for a couple of days.
  3. #13
  4. #14
    Mar 2004
    Bristol
    or could do a you know what on you know where
    I would take a couple. Only need 5 people wanting 2 each.
  5. #15
  6. #16
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Scouse Monkey
    lilliput should be same.
    Xenarc is oposite - which i cant get
    oh and you want 0.5mm pitch. but check all this before you order.
    FYI, all lilliput ribbon cables are NOT the same. Myself and others i've talked to own opposite facing cables in our lilliputs. you MUST know what kind of cable you need before ordering anything.
  7. #17
  8. #18
    Mar 2006
    It should I change a ribbon cable.I have one gain/xenarc monitor who cable it should I take from Farnell InOne?? Thanks
  9. #19
    Jun 2006
    Columbus, OH
    I have a Lilliput 629GL. Does anyone know what the cable is that connects the main board to the button/IR receiver panel? I need to replace it with a longer one.
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Broken Lilliput Cable
    By Mbai2 in forum LCD/Display
    Last Post: 05-19-2005, 04:47 PM
  3. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  4. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
  5. WTB ribbon cable for Lilliput
    By nthai in forum Classified Archive
    Last Post: 05-16-2004, 09:48 PM
