Results 1 to 10 of 19
Thread: Ordering replacement lilliput ribbon cable
    Newbie FLESIK's Avatar
    Dec 2004
    Adelaide, Australia
    Hi All,
    I need a replacement lilliput cable, cause mine is not very good.. I get lots of colorful lines all over the place when I turn my monitor on. I tried wriggling the cable around on the monitor while it was on, and instead found the CCFL inverter voltage across my hand.
    Only thing is that I'm in Australia, and postage is gonna be worth about 3 times what the ribbon is.. anyone in oz got a spare cable they could post over to me ASAP, I'd appreciate it muchly.
    Also I've been looking at ways to attempt repair on the cable, any suggestions from people who have had to do this sort of thing before?
    Cheers,
    Tim.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    if it is the internal 40 wire ribbon then look for a 40 way FFC cable. Farnell in the UK sell them so you should be able to get one in Oz.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    and before you order make sure you know which kind you need (same side or opposite side)
    Mar 2004
    Bristol
    lilliput should be same.
    Xenarc is oposite - which i cant get
    oh and you want 0.5mm pitch. but check all this before you order.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Scouse Monkey
    You got a part number on that scouse?
    Mar 2004
    Bristol
    Farnell: 335-2663 this is a 210mm, 0.5mm pitch, 40 core, same side Flat Flexible cable (FFC).
    I am usre they do different lengths in the catologue.
    Mar 2004
    Bristol
    i think that is the right cable. But you cant halve them.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I know that. But it folds in half to double back on itself in the lilliput.
    I was just trying to guage size and fit.
    nb pun intended.
    Mar 2004
    Bristol
    Quote Originally Posted by Enforcer
    nb pun intended.
    1st place 'ribbon' for comedy to that man!
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Broken Lilliput Cable
    By Mbai2 in forum LCD/Display
    Last Post: 05-19-2005, 04:47 PM
  3. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  4. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
  5. WTB ribbon cable for Lilliput
    By nthai in forum Classified Archive
    Last Post: 05-16-2004, 09:48 PM
