Results 1 to 10 of 15
Thread: Installing CD/DVD in Xenarc 700IDT
    Oct 2005
    Anyone with a Xenarc 700IDT try to install a CD into the empty space under the display? The faceplate clearly has a cutout that fits a slim cd.
    I was wondering where I would install my DVD with easy access then while taking apart my 700IDT for *****s and giggles I noticed what looks like mounting points. There is enough room in the area but mounting and securing it will require a little customization.
    Newbie Richard Alpha's Avatar
    May 2005
    Warwick, UK
    It's probably a good plan to take apart the IDT before installing it anyway - they seem to have lots of loose screws, so it provides a chance to tighten and thread-lock everything.
    Good luck with fitting optical drive - sounds like a good solution.
    Trying to fit a PC into an Alfa Romeo GTV. It's installed, but the buttons have fallen off since.
    Oct 2005
    Update from Xenarc
    I emailed Xenarc and they are working on adding this option in the future
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    It could DEFINITELY be done. In fact, it's nearly the perfect size of a slimline drive. I had an external slimline drive (a slimline drive in an external case. The external case added a few mm's to each side of the slimline drive so it couldn't fit in. But, I have a VERY GOOD feeling, a bare slimline drive would fit perfectly in that slot.
    I even think that you would be within the warranty limits, cause all you would need to do is drill two cutouts in the back of the 700IDT to feed the power and USB cable for the drive. I sold my unit to russman2000, so hopefully he will have some luck with this.
    -HD
    Nov 2004
    South West
    Any update on this?
    I am on backorder from mp3car.com store (2 weeks now..) for a 700idt.
    I would like to add the $99 slotload drive on the site into it but would like a little ressurance that it will fit + work before i add it to my order!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    Just had mine apart because I'm having problems, you can put one in, I'm planning on doing it myself. It has a connector on the board to power a cd/dvd drive. And yes you do want to tighten those screws up, half of mine were loose, plus they used too small of a screw on the small power board that attached it to the chassie. It was piratically just laying there. If it would of come out and set on top that board, kiss that thing goodbye. I'm very disappointed in the quality...
    Elsewhere
    Quote Originally Posted by hd54321
    I'm working on getting the slim slot-load drive. It sucks being a responsible adult.
    If this can be pulled off, however, then I've made my monitor choice.
    How about the Wiki?
    Oct 2005
    If this can be done im also gonna purchase one of these...
    something im sure would be of the greaaaaaaatest benefits would be if you post pictures and instructions during/(if u do actaully do this) installation.
    Nov 2004
    South West
    If there is a power connection on the board then the only other connection would be data right?
    I am presuming you will need a slim-line drive, connecting into this, a slim to ide converter (the one that comes with the slim drives in mp3car store) and from this into a ide to usb converter.
    First, will all this stuff fit inside the empty space?
    I would imagine if xenarc do fit one all this stuff will be fitted to the main pcb?
    Second, if it will fit, could the usb plug be cut off the ide/usb converter and the wires spliced/soldered to the touchscreen's usb connecter.
    Will two devices work on one socket? (i thought i read somplace that usb devices all transmit a unique id so you can connect loads up together)
    Not only would this save you the risk of drilling holes in the back of the case but my dash is SERIOUSLY TIGHT on getting that damm xenarc loom through places!
    Newbie visenri's Avatar
    Dec 2005
    Lightbulb
    This is my first post in mp3car forum, but i've been reading this forum for a long time .
    I have successfully installed a slim dvd-rom into a xenarx 700IDT, with its ide adapter and an ide to usb 2.0 converter.
    This is the post where you can see the "howto" (in spanish):
    http://www.solocarputer.com/phpbb2/viewtopic.php?t=3229
    I am going to install this screen in a VW GOLF V 1.9 tdi sportline.
    You can see the progress of my carputer here:
    http://www.solocarputer.com/phpbb2/viewtopic.php?t=2123
    I am from spain, sorry for my english.
  1. Xenarc 700IDT In DASH 7" Touch Screen IN STOCK!
    By Fiberoptic in forum LCD/Display
    Last Post: 12-15-2005, 09:12 PM
  2. Xenarc 700IDT is AMAZING!
    By spdyscotty in forum LCD/Display
    Last Post: 11-02-2005, 09:52 AM
  3. FS: Xenarc 700IDT For Sale
    By Purplxd in forum Classified Archive
    Last Post: 08-19-2005, 12:41 AM
  4. Xenarc 700IDT in Linux?
    By pkg in forum Linux
    Last Post: 07-08-2005, 03:21 AM
  5. Xenarc Announces their 700IDT In-Dash Monitor
    By Morgon in forum Input Devices
    Last Post: 02-15-2005, 02:29 PM
