Results 1 to 3 of 3
Thread: Help...Trying to install 7" TS in double DIN
    Oct 2005
    Hello guys. Here's my situation...
    I recently bought a carputer and trying to install a 7" T-View touchscreen/VGA monitor in a double din. The width and depth of the screen is no problem. It's the height that's causing all the trouble. My double DIN opening measures 4 1/4" high. The screen with the surrounding case measures 5 3/8" high. When I took the screen out of the shroud and test fitted it, the screen will fit near perfect if I don't use the bottom buttons (brightness, contrast, color adjustments etc.) Here's a pic of those huge buttons...
    http://www.five-stars.com/ebay/proinc/t-700ts.jpg
    Will it be a problem if I don't use these adjustment buttons? How often do you guys even use these adjustments? How effective will the screen work when it's not in the surrounding case? Will the screen even work without the 9 pin harness (8 black wires and 1 red wire)?
    Thanks!
    Elsewhere
    Try looking in the Show Off Your Project forum and seeing what other people have done for fabrication work in your situation.
    The way I see it, you have two options:
    1) Live without the adjustment buttons.
    2)Do some more fabrication work than anticipated to allow access to the function buttons.
    How about the Wiki?
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by DarquePervert
    1) Like without the adjustment buttons.
    I used the adjustment button once...In my second install I ditched those buttons and relied only on the remote.
  1. Lilliput 7" Cable help needed. (Bad 9pin DIN)
    By FireAnt in forum LCD/Display
    Last Post: 01-07-2011, 12:50 PM
  2. What screen will fit in a double din?
    By vdubpsu in forum Newbie
    Last Post: 06-07-2005, 04:46 PM
  3. 92 325i Double Din
    By rdcravens in forum Classified Archive
    Last Post: 03-29-2005, 08:42 AM
  4. Double din surround for Xenarc/Gain screen
    By Scarum in forum Fabrication
    Last Post: 10-12-2004, 03:39 PM
  5. 8" Lilliput LCD vs. double DIN?
    By hey_allen in forum LCD/Display
    Last Post: 09-02-2004, 10:42 PM
