Results 1 to 4 of 4
Thread: fix lcd ribbon
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    fix lcd ribbon
    I i started another psot today about my cheap LCD I bought from BB, http://www.mp3car.com/vbulletin/show...359#post652359
    so I decided to try and flip in manually, (I am flipping it so I cna use any input signal and it will look normal
    and to do this I needed to extend the rubbon that controls the LCD.. so I cut it, and now I'm having issues soldering new wires in.. mainly I'm having problems removing the protective coating that the wires are sandwiched in. I tried using a small lighter/tourch to burn it off.. and the wire isn't too brittle. but the coating doesn't burn off, what should I do?..
    I feel like I jsut hosed my LCD.. it was perfectly good and I jsut can't leave well enough alone :-).. looks like my wife is right again.
    can anyone offer tips and or help.
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Fusion Brain Creator
    Mar 2005
    ohhhh mannn, way wrong move
    it's hard enough to keep those things working uncut
    how many wires is it
    Nov 2004
    Ham Lake, MN
    32 in less than 1 inch :-)..
    I thoguht about it for a while and figured, I can do this.. I got 4 done.. and then they start to crack as I keep working on the others. and taking off the coating is ahrd too..
    Shawn
    Nov 2004
    Ouch, tried that once with a faulty PDA display!! If the wires are still contained in a single ribbon then use a very sharp scalpel/knife to scrape the coating back to bare wire. This takes a while cos you need to keep the blade parallel with the ribbon with even pressure - should get the coating off evenly across all wires. Then use a wide solder bit and run fresh solder across all the wires in a single stroke, okay may be more than one . Stick the ribbon to a surface to keep it steady and now for the fun of extending - use another ribbon and repeat the process then line it all up and stick the extension down. With a bit of luck and both sets of wire freshly tinned, use just the heat of the iron to get a join. Search the web for a company called Chipquik and grab a sample of their low heat solder, it can be melted with hot air (not a standard hair-dryer though...I don't think) and by passing the iron above the wire with no actual contact. Good luck.
    BTW when done, fix the joins with a coating of quick set two part adhesive, essentially potting the joint, preventing it from flexing and breaking.
  1. FAQ: Using a Laptop LCD as Your Car PC Screen
    By cproaudio in forum The FAQ Emporium
    Last Post: 06-09-2009, 11:03 AM
  2. FS: 7" Lilliput LCD + TOUCHSCREEN
    By calvincbr in forum Classified Archive
    Last Post: 04-09-2005, 03:36 AM
  3. BYO LCD Projector
    By NiN^_^NiN in forum Off Topic
    Last Post: 03-29-2005, 04:47 PM
  4. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 02:46 PM
  5. How do you fix alternator noise on an LCD?
    By adamis in forum General Hardware Discussion
    Last Post: 08-23-2003, 08:31 PM
