Results 1 to 10 of 12
Thread: xenarc touchscreen backwards movement
    Jul 2005
    Colorado
    Touchscreen had been working great.
    Did a major overhaul of software and wiring in car and now everything is back to life as normal except for the touchscreen.
    When I touch the screen the pointer shows up about 1 inch away.
    When I move the touch up and down the point goes side to side.
    Tried re-installing the software and it says it can't find any controller.
    How can it partially work if it can't find the controller?
    Nov 2005
    same problem with MTSVO-SC
    I have the same problem with my touchscreen on the k301 flip out motorized screen. I tried re-installing the driver and it did not work. I seriously tried getting it to work for over 10 hours. A full waste of day, I was super disapointed cause it was the first time the unit was out of the box even.
    Good luck
    Nov 2005
    sounds like mine. the x and y axis are switched. up and down moves the pointer left and right. left and right moves it up and down
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    try recalibrating the ts you noobs
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Yes, but if the TS config software can't find the controller, you can't recalibrate...
    I've had that problem more times than I can remember. It's usually solved by restarting. Then I'm able to recalibrate. Must be some sort of a driver issue...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Aug 2004
    unistall, reinstall, reboot, it will work eventually
    Newbie a-ron's Avatar
    Apr 2005
    North Cali
    When Did you get it? Had the same thing happen. The Drivers that come with the screen do not work!!! Had to down load them from web page. Than all was great!!
    Remove the old,
    download the new...
    Raw Wave
    Jun 2004
    On the beach
    try the egalax touchscreen drivers, also check that the drivers have installed properly in Device Manager ... sometimes they don't always install correctly and leave some of the drivers uninstalled. Manually installing through device manager will fix this.
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Quote Originally Posted by jayearl
    Your operating system is trying to make it work for you.
    Quote Originally Posted by EsKALad
    Come on man - being from Illinois I woulda thought you'd be smarter than that! How do you calibrate if the software can't find the TS?
    Solution:
    I actually had the same exact problem with my Xenarc last week. I tried pretty much everything. I used the same exact drivers as I had used when it worked - and I had the same problem you described. After getting frustrated to all hell, I actually did a
    I went to Xenarc's website and found out they had a new version of the drivers. Newer than the version I had been using. I downloaded those drivers, installed and it worked great.
    The new drivers are only like 2 months old:
    http://www.xenarc.com/driver-touch1.html
    I'm 100% sure this will solve your problem. Goodluck
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Jul 2005
    Colorado
    SnyperBob you are correct.
    The drivers that come with the screen and windows drivers do not work.
    Installing drivers from Xenarc web site fixes everything.
    I have chucked the xenarc install disk into the garbage
    never to be put in the computer again.
  1. WTB: Xenarc Touchscreen and Panel ONLY
    By ayclens in forum Classified Archive
    Last Post: 04-24-2005, 03:13 AM
  2. FS on eBay: Via10000 LVDS and Xenarc 7" VGA touchscreen
    By lemming in forum Classified Archive
    Last Post: 04-10-2005, 03:03 PM
  3. Xenarc 7" LCD, but no touchscreen
    By celicagtsblak in forum LCD/Display
    Last Post: 09-27-2004, 11:27 AM
  4. FS: 7" Xenarc 700TSV TouchScreen
    By qjones in forum Classified Archive
    Last Post: 09-02-2003, 09:28 AM
  5. finding touchscreen in xenarc
    By ELEmental59437 in forum Input Devices
    Last Post: 06-25-2003, 12:47 PM
