Results 1 to 7 of 7
Thread: 700IDT - Tilt question
    Aug 2005
    I know this thing is spring loaded. Can I adjust the degree of the monitor?
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    I haven't been able to find a way.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    I too am wondering how to tilt it. Even the manual shows how it tilts 15° in either direction, but I can't get it.
    Anyone called tech support yet?
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Low Bitrate Serialk1llr's Avatar
    May 2006
    Holy thread revival batman!
    I too am looking to figure this one out, or am I stuck wedging a sock between my dash and the back of the monitor?
    Current Rig
    Inspiron 5100 Laptop
    *2.2 Ghz CPU
    *368 MB Ram
    *32meg OnBoard Vid
    Carnetix 1900 PSU
    BU-353 GPS Antenna
    iGuidence Nav Software / Mappoint for POI's
    Linksys USB WiFi
    D-Link USB Bluetooth 2.0
    Xenarc 700IDT
    Eclipse CD4000 HU
    May 2007
    The 15 degrees is left/right not forward/back so in order to prop it up forward you would need to wedge something I guess.
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    Man this thread is 2 years old. GEEEE
    If you want to change the tilt of your 700IDT, you could add some rubber to the cushions behind the screen that are used as bump stops against the metal brace. If you want to angle it up, you could remove the bump stops and get a few degrees up.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    some threads just won't die ...
    I just finished installing the 700idt in my dash and i found it's pointing to the ceiling too much.
    When dismanteling the thing i found a stopper with two screws (i know i should have taken a picture)
    I tried to move this thing forward, but it blocked the screen tilting mechanism. Has anybody tried bending this thing ?
    If i take it out of the dash again i'll take some pics
    ok ... just spent some more time looking at this thing. It seems you can easily change the tilt angle of the screen by adding some extra padding to the support and the back of the screen. In my case I added a 1mm thick piece of plastic to the back of the screen and a second 1mm piece to the support.
    Any more on the back of the screen and it won't close anymore.
    Also be carefull not to block the opening motion of the screen when adding thickness to the support. I only added a 3mm thick strip to the top. Seems to do the trick perfectly without getting in the way of the opening screen.
    Hope this helps
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
  3. Quick 700IDT Question
    By ukchris in forum LCD/Display
    Last Post: 06-13-2005, 09:43 PM
  4. Decision time...DWW-700M or 700IDT?
    By taimoor in forum LCD/Display
    Last Post: 05-19-2005, 01:32 PM
  5. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
