the model is the VM80 if that helps.
i ordered this touchscreen and it comes with usb drivers and all the needed stuff. when i instal the drivers and try it out a few things happen.
its almost like the x and y axis are switched because were i touch and were the cursor goes are way off. BUT if i turn the screen 90 degrees clockwise then it works the way it should except now the screen is sideways.
also whenever i touch the screen my computer makes a loud beep.
should i just plan on sending this thing back?
upside down?Originally Posted by cass944
no, its not upside down. just 90 degrees off. the desktop image is the right way. so as a monitor the screen works fine. but if i touch the right sode of the screen the cursor goes to the bottom. if i touch the bottom it goes to the left side of the screen. if i touch the left it goes to the top. and so on. its just 90 degrees off i guess. i cat explain it any better than that. when i goto the settongs and goto add new panel list and click add. it says no more controller.
have you tried running the worcol configuration program?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
yeah like i said in the settings were there is a list that hsould list any monitors you have hooked up it list nothing. and i cant configure anything without clicking on something in that list first. so whatever i think this things going back.
here are some pics of the screen.
finaly got it figured out. i got the newest drivers from egalax and got it working perfect.
also just incase anyone ever gets fruestrated with the calibration thinking it doesnt work because the X never goes away.... you have to touch and hold your finger on the X until it goes away... i was just tapping it and nothing was happening and it was making me mad for a little while.
