slightly off topic...
could you post pics of the 700H setup in your TC - I'm considering getting one...
bump
btw - device manager perhaps?
Okay....this is weird. I bought a the DWW-700H non motorized. BTW, The screen is very nice. Not perfect. But still great.
Using the drivers that came with it (WolcorTech) the unit kept thinking I was touching incorrect points and the computer would beep annoyingly.
Trying to run the configuration utility, The program would complain "No More Controller" and never let me run calibration.
So I un-installed and tried out the egalex drivers. The program would be able to run calibration and the draw test perfectly. However, outside of those two programs...anytime I touched the screen the mouse would not move.
Has anyone had this problem or know of a solution? I tried contacting digitalww but they haven't responded for a few days.
bump
Not yet. But soon, I'm still trying to get the whole thing working once before I install.Originally Posted by bagwellfive
So.
Worcortech drivers + TS = Badly calibrated mouse actions with no recalibration available since the config utility cant find the controller ("No More Controller")
Egalex + TS = perfectly calibrated mouse while ONLY in 4pt calibration or Draw test. When draw test and cal util are closed, using the touchscreen doesnt move the mouse at all.
Is there anything special that needs to be done to get the egalex drivers to correctly act as a mouse.
see if anything here is useful...
TouchScreen Drivers & Installation
thanks anyways folks.
My problem is fixed. Re-installed windows and installed the egalex driver before my 4in1, vga, audio, lan drivers. It must have been an irq conflict. I still think the worcortech driver suck
Scion tC 2005 with DWW-700H
Via Eden M10000, 512MB, 100GB 5400rpm, Xp Pro
congrats on de-bugging...Originally Posted by tC_install
nothing better than the feeling of debugging and having everything working...
now post pics! lol
LOL!
Pics will come late next week. I have some final apps to buy/install and then a whole lot of drilling to make this fit right wihout a double to dual single din enclosure
I have a 700H too.
To bagwellfive: Yes i like it, screen is clear & bright, more robust & movable than the s...t motorized enclosure i had from DWW.
I have a bizzare driver problem, but different from yours TC_
I install the 4.02.1929 drivers, it all works ok when i run the touchkit program, but after a reboot it doesnt load the driver automatically (but ok again after i run touchkit manually)
I may try a reinstall & load drivers before others (I have intel chipset not Via 4in1)....
Anyone else seen this?
