Results 1 to 7 of 7
Thread: Proper resolution for SP-719/S-1016 LCD?
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Question Proper resolution for SP-719/S-1016 LCD?
    Got the LCD in and so far am fairly impressed. The OSD is super sharp and the LCD in general is bloody bright. However, I can't find a good resolution that suits this monitor! Everything seems to flicker.
    Anyone know a solution?
    PS: It's that SUPER/AVATAR eBay LCD.
    gbh
    gbh is offline
    Constant Bitrate gbh's Avatar
    Oct 2005
    Massachusetts, USA
    Quote Originally Posted by LiquidKernel
    Mine looks great at 800 x 600 60Hz. No flicker at all.
    Feb 2005
    Hmm, what drivers did you use for the monitor?
    Feb 2005
    Okay it seems like I am getting a bunch of flicker on this screen at any resoluton and at any refresh rate (60Hz). The OSD is fine but the inputs are not... sonwder if it's just a defective LCD?
    gbh
    gbh is offline
    Oct 2005
    Massachusetts, USA
    I have it running off a laptop with ATI Radeon IGP 8mb.
    I have also had it running off a Radeon x300 128mb and an old 633 celeron with like 1mb on board.
    I did have to play with my laptop to get it to work right - upgrade driver, play with dual monitor settings, etc.
    You might try hooking up another monitor and running at 800 x 600 - if that works fine it may be the lcd.
    If you took it apart I would also check all connectionc/cables.
    Good Luck!
    Feb 2005
    I tried it on my laptop and it the image is flickery as well (any resolution). So it seems like it's the LCD having an issue.
    Haven't opened it up yet.. might consider getting it RMAed.
    Oct 2004
    800x480 with epia sp13000
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. What resolution for 7" LCD
    By Mp3Goose_Your King in forum LCD/Display
    Last Post: 02-25-2003, 05:17 PM
  3. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  4. lcd resolution
    By meth84 in forum LCD/Display
    Last Post: 09-26-2001, 07:50 AM
  5. resolution for 4" lcd from partsexpress
    By noproblem in forum General Hardware Discussion
    Last Post: 07-11-2000, 08:23 AM
