Results 1 to 10 of 14
Thread: Burnt cap on Lilliput 7"
    SJC
    SJC is offline
    Calgary, AB
    Exclamation Burnt cap on Lilliput 7"
    The other day while driving the screen just shut off, but the touchscreen still functioned, then I started to smell burning. Took it all apart once I got home and found the relatively obvious problem (below the red arrow).
    Anybody know the specs on this part (I assume it's a capacitor?), or ANYTHING that will help me to replace it?
    Help is very much appreciated!!
    Oct 2005
    Idaho Falls, ID
    are the specs not listed any where on the part? possibly solder if off the board and check the underside too.
    Maximum Bitrate Rundell's Avatar
    I'm not sure what that is but I don't think its a capacitor.
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Fusion Brain Creator
    Mar 2005
    says C683 next to it
    SJC
    SJC is offline
    Calgary, AB
    I will try soldering it off but I can see a little under it and I don't think there is any writing...
    I put together this pic about other markings on the board and the components - half the reason I thought it was a capacitor was because of the 'c' in front of the number, but if anyone knows what the 'c104' item is, it might help figure this out.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey if u dont end up fixing it ive got the same board out of a broken lilli im not sure if it works but if ur interested in buying it i will try it out and let u know
    SJC
    SJC is offline
    Calgary, AB
    After speaking with someone at work who knows more than I about electronics, I've been told this is part of the backlight circuit. I know there are some posts on here about upgrading the backlights and have read through them, but they don't mention anything about the circuit yet.
    Any help from the backlight folks would be super appreciated.
    Mar 2005
    you probably can't replace the part. you can replace the whole inverter.
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Of course you can replace it!!
    Its a capactor. Looks like a polyester.
    Its hard to tell from the pic but it seems to be on the low voltage switching side of the inverter.
    one question is why did it go short? It could be a simple component failure (heat, voltage...induced)
    The trick will be to find the right value/voltage. If someone with one which has not had the markings burnt could post the text it may help.
    HoSS
    Oct 2005
    It looks to me from the picture and the numbers that it's an inductive capacitor. 2L 02 is found on many similar components but without knowing for sure what the rest of the H1?? is you are going to have a hard time finding it. Maybe someone who has a broken Lilli can look on theirs for you.
    Hoss is right; you need to find out why it burnt. My plan of attack would be find the part at a supplier (you can submit inquiries at tons of places on the net- Google it “electronic components”), order at least 2 (they will be cheap if there is no minimum order), replace it and see if the component simply fizzled on its own. If not, you will have the other to put in when you find the actual cause.
    Progress: [xxxxxxx---]
    All components purchased (AGAIN!).
    2 Lillipoops lilliplopped, working on #3 (DWW-700M This time).
  1. FS: 7" Lilliput w/ TS and CNX-P1260
    By brandon in forum Classified Archive
    Last Post: 09-19-2004, 11:39 PM
  2. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 08:46 AM
  3. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  4. In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen
    By JonX69 in forum LCD/Display
    Last Post: 03-06-2004, 02:22 PM
  5. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
