Results 1 to 8 of 8
Thread: What I want in a Doube-DIN motorized LCD.
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    How to do a CarPC if you have a double-din? Too often the doube-din is too small for a full PC, and space-wasting with just a flat-LCD on the front of it. I've seen DIN-PCs and DIN-LCDs, but I need more space and like having a bigger computer in the trunk. The problem is wiring everything from the trunk to the cab. I therefore thing a good double-din LCD / secondary case would be an awesome product. Here's my thoughts on such a case:
    The monitor would come out of the center and have 4 positions:
    1) Closed: The monitor is retracted in to the center displaying the buttons like the DWW-700M does.
    2) Open: The monitor comes out of the slot held by two arms (one on each side of the center LCD slot), then spins to face the user at one of 3 angles, then retracts a bit (once the monitor is spun flat, the arms can retract to bring it closer to the face of the unit).
    3) Load-Disc: The monitor re-extends (so it can spin), then spins so the light of the LCD illuminates the top half of the double-din unit. A slot-load DVD player at the top of the unit would then eject the DVD/CD.
    4) Security: The LCD would spin so that you are looking at the back of it. It would then retract to fully cover the face of the double-din unit. The back of the LCD could say "Security" on it in yellow and have a red flashing LCD.
    The bottom half of the unit would have deeply resessed USB slots (so that most normal size flash-keys could be left inserted when the monitor is in security mode). The slot-load DVD on the top would be the slim laptop-sized with a USB-to-SlimCD adapter.
    In addition to the slot-load DVD on the top, the space inbetween the LCD and DVD could have a 2 or 4-line character LCD and some buttons for using the CarPC with the touch-screen LCD closed.
    This unit should come with VGA, USB, and non-regulated 12V/GND/Ingition input (with all that room, why not include a 12V/5V regulator to power the screen, USB hub, and the DVD-ROM). The Ignition would have to triger a count-down to auto-Security mode the screen and then fully unpower the screen & hub (no dark-current drain). Actually on second though, you should use the PC's USB 5V power as the switch, not Ignition.
    A single USB connection to the PC should connect to a powered hub that provides recessed USB ports on the bottom, the Touch-Screen controller, the USB DVD-ROM, and the character-LCD/button interface.
    It would be really cool if the button's were just the normal up/down/left/right/enter from a normal USB keyboard. I'm not sure the best way to do a character LCD interface... maybe a USB-to-Parallel Port chip? To really pimp it out, you could add a tempature sensor and maybe some Internal USB slots for things like blue-tooth or WiFi USB dongles. Maybe even an internal HDD with the IDE-to-USB converter too (laptop and/or normal since you already have regulated 12V for the screen).
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I don't see the point for point #1... IMO it would make it much more complex than it has to be.
    Nov 2004
    L.A.
    I see what you mean, but for it to spin to both viewable and security the way I want, it would need to be held by two arms, one on either side of the center. Therefore it doesn't really make it any more complex to just have a hole and a 4th position.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by RPM_VR4
    Having the arms retract fully backwards (to hide the LCD like in the DWW-700M) would make it more complex.
    Nov 2004
    L.A.
    Why? It already needs to be able to extend to spin the LCD and contract to hide the face in security mode. It's just making it able to contract a little further.
    Jul 2004
    Berkeley, CA
    Well, that's harder. You don't see the kenwood screens retracting inward. Try drawing up a quick diagram and posting it to give people some idea
    Nov 2004
    L.A.
    What do you mean? The Kenwood screens do retract, they just fold up from the bottom instead of spinning from two center arms like my idea.
    I did draw it out on a piece of paper, but I haven't the graphics talent to post something I wouldn't be embarrassed of
    FLAC -zip-'s Avatar
    Ontario/Canada
    I want my own personal rocketship but they will never make that either...
    Sound Stage
    Eclipse|MTX|Infinity
  1. WTB: Motorized LCD Housing
    By jcdillin in forum Classified Archive
    Last Post: 07-04-2005, 10:25 AM
  2. 2003 Civic Coupe LCD in Din?
    By thecolor in forum LCD/Display
    Last Post: 07-01-2005, 12:05 PM
  3. Motorized Door To Cover The Lilliput LCD
    By Xtreme2k2 in forum Input Devices
    Last Post: 12-17-2004, 04:22 AM
  4. Double Din Kit for LCD Mount?
    By Plinkey in forum LCD/Display
    Last Post: 07-13-2004, 11:41 PM
