Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Blurry Lilli 8" TS... :(
    Apr 2005
    Haven't been able to find anyone else with this prob, so:
    I've been running my CarPC for a few months now, but it's really been bugging me lately...I want clear font/pictures on my screen.
    The only resolution I can pull up using XP is 800x600...and I think the problem might be that the native resolution of the screen is 640x480?
    I'm running the MII 10k mobo. Any other info needed?
    Any suggestions?
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I also have the 8" Lilliput, and I know what you mean. Use 640x480. It looks good at that resolution. Any other resolution other than it's naitive of 640x480 is going to look blurry. Make sure you have the latest touchscreen drivers here.
    And also enter in the codes to have it auto power on, as discussed here. (see post #58)
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Apr 2005
    Ohhh ok. With the updated drivers will I be able to select 640x480? Because right now my only option is 800x600...
    I will install the new drivers though, thanks!
    *Thank goodness someone else has had this problem!*
    Apr 2005
    Well, I just installed the new TS driver and did the 4pt calibration, and the screen looks as it should (crisp lettering and all) eventhough I didn't change the resolution.
    Also, I can't move the cursor on the screen with either my finger or the stylus...the mobo just keeps beeping at me. WTF...
    Apr 2005
    Ok, went out again, plugged in a PS/2 mouse and got the TS working. The screen was fine (sharp) for about 30secs then instantly turns back to being blurry again... And I still can't select any resolution or refresh other than 800x600/60hz. :\
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    dude im running my 8 inch lilli at that resolution and its crystal clear. i dont know why your is doing that.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    some lilli are 800*600 native, others are 640*480
    by the way using 2k/xp you can select 640*480 res under screen properties/settings/advanced/adapter/list all modes
    try 60 or 75hz, see wat works better for your screen
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Sep 2003
    Tampa, Florida
    I had a problem similar to that (XP not offering naitive resolution) on my laptop, and maybe this can help you. D/L and install Powerstrip, (free) then select 640x480. Then reboot. Then once it is working, un-install Powerstrip. Re-boot, then it should allow you to do 640x480 in XP.
    WORKLOG
    Webpage
    Apr 2005
    Quote Originally Posted by Frankino
    Nope, I tried that before. Only lists 800x600 and 60hz.
    Apr 2005
    Quote Originally Posted by Snootch
    Well it seems the screen is sharp again...it's weird... :\
    But if it happens again I will install PowerStrip, thanks.
  1. FS: 8" Lilli TS (newer model) & Mac Mini & Inverter
    By shizzle in forum Classified Archive
    Last Post: 07-23-2005, 09:27 PM
  2. 7" or 8" Lilli ?
    By raceer in forum MacCar
    Last Post: 06-03-2005, 12:05 AM
  3. Lilli ghosting. Searched and still need help
    By maxxell in forum LCD/Display
    Last Post: 03-24-2005, 04:01 PM
  4. Need Help with my custom console to house 8" Lilli
    By Gordinho80 in forum Fabrication
    Last Post: 12-03-2004, 05:04 PM
  5. Prob w/ 8" Lilli ts. flickers after boot.
    By Ninety8NeonACR in forum LCD/Display
    Last Post: 05-07-2004, 01:55 AM
