Results 1 to 10 of 18
Thread: Install/Power in dash LCD
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    I've never done a radio install in a car and was thinking of buying an in dash LCD.
    http://www.digitalww.com/DWW-700H.htm
    Looking at the photos(http://www.digitalww.com/images/DWW-...losed_side.jpg) all I see is a USB(touchscreen) and some PS/2 looking wire coming out of the back of this thing which I believe connects to a included VGA cable..
    My question is how do I power this thing? I noticed other in-dashes(http://www.digitalww.com/images/DWW-K301_back.jpg) have a 2by3 molex-style connector w/ power, gnd, acc, etc.. I imagine this is standard for radios? and when i remove my radio there will be one of these connectors attached to my existing radio? Is this true, there being a standard 2x3 radio connector for power/gnd/acc/etc...? Ive seen/heard of wiring harnesses, will I have to get an adapter to convert from my cars wiring harness type to the in-dash lcd's type?
    Also when looking at the photos of the included wires(http://www.digitalww.com/images/DWW-...cessories.jpg), i only see VGA and and a couple RCA.
    I am very confused because the scriptions states it comes with usb, vga, video, and power wires.
    Oh and if I have a head unit AND the in-dash, and only one wiring harness... how do I get two harnesses?
    Thanks.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Something's pluggin in there to power it.. http://www.digitalww.com/images/DWW-...ccessories.jpg
    See the small red wire at the bottom of the middle pack of wires? Wire that up to your +12v (preferrably regulated).
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Sep 2005
    Seattle, WA
    So if that is the case, then I would not need two harnesses, but I would probably need a bigger PSU(I was going to get the m1-atx, which has 2A on the 12V rail).. I would be using a m10000, and a 3.5"HD. I think those alone push the 12V rail to its limit, no?
    ps. you got good eyes.. i stared at that pic for awhile and didnt see that red wire.. looks a little thin for a power wire.
    B Smoov
    Sep 2005
    Seattle, WA
    FYI
    I contacted digitalww about the LCD and they didnt have any further documentation online but they did confirm there is a PWR/ACC/GND/SAFETY wires.. The safety being a wire connected to the ebrake so that the monitor will not display if the car is moving.
    I requested getting the manual online.. we'll see if that happens. that'd be cool.
    B Smoov
    Sep 2005
    San Luis Obispo, CA
    Quote Originally Posted by buurin
    Riiiight...
    -arebelspy
    Sep 2005
    Seattle, WA
    Gotta make sure i dont forget to connect that safety wire!
    B Smoov
    Sep 2005
    San Luis Obispo, CA
    Doesn't everyone pul over to check their GPS's screen?
    -arebelspy
    Oct 2005
    Australia, WA
    I have that screen and it does not have a safety wire as far as I can see.
    Works nicely though.
    There is however 4 wires. Ground (black), 12v+ (red), ACCC (green i think) and another ground which is Blue if i remember corectly.
    Not exactly sure on why it has 2 ground wires listed, I can scan the booklet I have when I get home if you like ?
    Also why would you run this from regulated? Its built for use in a car so it should really be fine off the standard 12v power source. I mean I can understand a computer not being able to because its not built for the varying voltages but this is designed to fit in a din bay in a car, it has to be built for it.
    Low Bitrate NickFury's Avatar
    Nov 2004
    Worcester MA
    Quote Originally Posted by claymen
    How do you have yours hooked up? Off a powersupply?
    I was thinking of hooking mine up to an accessory source, like the cigg lighter for a while (Hardwired behind the cigg lighter obviously). Will this work? I'm just worried about a power surge or spike and a smoking 700H
    And whats everyone take on an 'inline' fuse on the 12v red wire if I went this way?
    Later down the road I'm going to put a full PC in the trunk, but right now all I got is a screen, laptop and inverter Not the best setup I know, but it's all I got/can afford right now
    Hopefully hooking it up this afternoon, I'll try and get pic's up later after I do it for you guys
    Sep 2005
    Seattle, WA
    Well most LCDs expect regulated power... I figured since this is in a DIN case it would expect a raw 12V from the battery, however it is so cheap I wouldnt be suprised if they didnt include a regulator in it.
    And that 2nd ground wire IS the safety wire. At least thats what digitalww told me. Somehow you connect it to your ebrake... Basically I think if it is not grounded then your monitor will not come on(i suppoose you can try it).
    Powering from the cig isnt a bad idea. I really really dont want to connect it to my PC PSU.. One because I dont want to run power from the PSU, and two because I dont want to put a 1A draw on the device which will already be running a 3.5" HD.
    good to hear it works well, i hadnt heard of anyone using it. cool. is the left/right tilt useful? thats why i think i'll like it more than the motorized w/ no left/right tilt.
    anything I should know about installation?
    B Smoov
  1. WTB: Opus 150 and motorized in dash lcd
    By Synth3t1c in forum Classified Archive
    Last Post: 09-13-2005, 09:08 AM
  2. FS: in dash lcd housing
    By Motorcity in forum Classified Archive
    Last Post: 08-17-2004, 12:56 PM
  3. 15" bilt in dash LCD idea
    By beaverpants in forum LCD/Display
    Last Post: 03-31-2004, 03:53 PM
  4. 6.4/7 inch in dash LCD?
    By Rireal in forum LCD/Display
    Last Post: 01-23-2004, 10:44 AM
  5. Anyone want a Clarion 5.6" In Dash LCD?
    By gguy in forum LCD/Display
    Last Post: 05-30-2001, 11:29 PM
