it would be too expensive ive got white 5mm 50000 mcd leds and those r liek 3 bucks a pop! but my god r they bright... the only thing u will have to think about is that oon the screen its gonna have dots because its so close and leds r like directional and kinda project the light
LinkBack URL
About LinkBacks
) I learned pretty quickly that the MCD rating isn't very useful until you twist it around a bit.. so I made up this calculator in excel. Enter in your LED's Properties, screen dimensions, and itll give you the info you need to see if it'll work. (most importantly the cd/mē).. it also gives a percentage of how visible the LED array would be against 100% direct sunlight. Something it doesn't take into consideration is touchscreen overlays and the screen's gain... however, it gives a good start.
