Results 1 to 8 of 8
Thread: LCD problem
    Nov 2005
    LCD problem
    I got a 14" screen and a computer that is already in the car..
    the only problem that i have that the connector on the motherboard is regualer VGA Monitor port.
    But the screen is from the Laptop.
    So my question is there any connector or switch or information for LP141XA A1 Screen.
    Aug 2005
    Corinth, MS
    You're not going to be able to use that laptop screen with your computer. Laptop LCD's use a purely digital signal and you would need a lcd controller that probably doesn't exist to convert it to VGA or DVI. Even if you could find the controller, it would cost hundreds of dollars.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Skr4tCH
    Google is your friend:
    http://www.eio.com/public/lcd.2001/1612.html
    Nov 2005
    Thanks for the help people..
    SO you sure there is no way i could make it work?
    here is the screen.. whats the left cable and whats the right cable?
    Apr 2000
    Bedfordshire, UK
    You might be able to use a DVI to LVDS converter to drive that screen from a standard DVI graphics card. It's on special at $600 here : http://www2.dvigear.com/mudtolvad.html
    I'd recommend you give up on this route though and look for something more reasonably priced.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by 06stang
    Not true. I use controllers for LVDS panels everyday.
    Apr 2003
    Detroit, MI
    Quote Originally Posted by Rob Withey
    That controller you reference is for a specific monitor, namely the Silicon Graphics® 1600SW. That controller is a dedicated part, and won't run just any old lcd panel.
    Apr 2003
    Detroit, MI
    I have a controller for that panel. Won't set you back hundreds either.
  1. LCD fuzzyness problem...???
    By citrus3000psi in forum General Hardware Discussion
    Last Post: 08-20-2006, 07:49 PM
  2. lcd problem
    By corsab in forum LCD/Display
    Last Post: 11-20-2004, 01:26 PM
  3. LCD Double Character problem
    By wyllson in forum LCD/Display
    Last Post: 11-13-2004, 10:03 AM
  4. Video Card / LCD Problem?
    By JackMode19 in forum LCD/Display
    Last Post: 07-26-2001, 10:42 PM
  5. Serious LCD problem! HELP!!!
    By embedded in forum Software & Software Development
    Last Post: 03-28-2001, 12:14 PM
