Results 1 to 4 of 4
Thread: No red color in monitor
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    First, I wanted to appologize if this issue has already been addressed as I have searched, but am not sure that I am using the right words when specifying my search...if it has been addressed, go easy on me please...
    I am having a problem with the colors in my 7" touch screen.
    My install:I installed the screen into my dash, but I had to take the backing off of the monitor in order to make it fit. As a result, the mainboard is hanging loose behind the monitor and the only thing connecting the main board to the screen part are two ribbon cables and the touchscreen controller cables. The mainboard does not move around at all since these 3 cables along with the vga connection almost wedge it behind the dash in a way that secures it.
    Problem: To my understanding, there are 3 colors to an (RGB) LCD monitor....red, green, and blue. My monitor seems to only be displaying green and blue. The red color used to occasionally "flicker" in when I would be driving and if I tap my hand on the side of the dash...sometimes it flickers in and then stays there (so everything looks fine) until the next time I restart the system. This was extremely annoying, but now it seems that the monitor is only displaying green and blue without the flicker.
    This is what im thinking....either there is a loose ribbon cable behind the monitor, or a ribbon cable is being pulled.
    Can a pinched VGA wire cause this type of effect?
    Can anybody help me confirm the problem or lead me to a possible solution...any input is greatly appreciated
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    You can have this problem is a wire is loose, I would start at the computer, and unplug everything and plug it in again, making sure it all the connections are tight.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by zPilott
    I know that the problem is probably somewhere behind the dash because when I tap the side of the dash, the screen will flicker...has anyone heard of a loose ribbon causing this problem? If so, how would I "tighten it"?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    bust open the monitor and try to put the ribbon back in correctly shud work its happend with my lilli put
  1. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  2. Replies: 1
    Last Post: 04-10-2005, 06:24 PM
  3. Replies: 1
    Last Post: 03-23-2005, 12:41 PM
  4. FS- Datalux TS monitor, Prim View TS monitor,
    By coachreed in forum Classified Archive
    Last Post: 03-10-2005, 11:02 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
