Results 1 to 4 of 4
Thread: Auto-on in a mysterious way
    Newbie FrodeS's Avatar
    Aug 2005
    Norway
    I don't really know how it happened, but I've somehow got auto-on on my Liliput / newision 829VT
    It happened last saturday. I had been using the carputer too long, so the car did not start. The display get power when i turn the key. I had enough power to glow, but not to start, so when i tried to start, the power to the display shut down. I tried several times, also with at battery charger with starter (not powerfull enough for my diesel), and whith another battery and jump start cables. Neither worked, so the power to the display was a lot on/off . The last time i tried, i noticed that the display was auto-on, and it still is.
    Can anyone explain how this happened?
    I was in a hurry, so I ended up driving the volvo instead, while the benz was recharging. 54ah (optima red top) is to small to use the carputer for some houers without running the engine. A new 100ah gel-battery is ready to be mounted.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It happened to one of mine as well.
    That screen now has a problem, don't know it is related, the colours started to go and now I only get the white screen of death. I would advise you replace the Lilliput egg with a better 12V regulator. (if you are usiong the lilliput egg that is)
    Aug 2005
    Norway
    Quote Originally Posted by Enforcer
    Hello. The display clearly had some type of "reset", cuz the language was changed to chineese, japaneese or at least something that I was not at all able to read
    I am using the 12v regulator that came with the display, but it is not the classical "egg" This one is totally square.
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. Auto resume no longer works
    By Cruizer in forum RR Bug Tracker
    Last Post: 09-20-2005, 06:08 PM
  3. Replies: 2
    Last Post: 10-17-2004, 05:00 PM
  4. Auto DJ function proposal.
    By kid320 in forum Media Engine
    Last Post: 07-26-2004, 06:35 PM
  5. Auto DJ function proposal... opinions?
    By kid320 in forum Software & Software Development
    Last Post: 07-26-2004, 11:07 AM
