Results 1 to 4 of 4
Thread: Dim LCD based on ambient light
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    I know there ahve beena few threads on this.. but I couldn't find much in the way of answeres.
    1) Is it jsut a matter of adjsuting the Hhigh Voltage line to the CCFL? I would assume it would be better to do that than pull the voltage down for the whole thing, although maybe easier.
    2) Maybe someone could help me / all of us, with some plans for building such a regulator?
    No, software gamme control isn't what I'm thinking.. all gamma does is shift all pixel values darker, less white .. but the black the same.. because even a black image on a screen makes light ..
    I'm just saying it would be nicer to have it use a photocell of somekind to control the actual luminance of the CCFL.
    just one more thing for me to break :-)
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    The land of polar bears and nekkid blonds
    JC and Scouse is working on a dimming solution:
    LCD Backlight Upgrade
    ...and there are VGA controllers with dimming input.
    ...and there are software controllable VGA controllers.
    (with "VGA controller" I mean the VGA driver board connected to the panel itself)
    I intend on using software since my car allready have a sensor that I can access through the car's internal bus.
    /M
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    I am working on a backlight upgrade based on OSRAM Golden Dragon leds with photo-transistor which increase or decrease backlighting in fonction of quantity of ambiant light. When ther is direct sun light on the screen, the backlight will work to the mawimum of capabilities.
    Nov 2004
    Ham Lake, MN
    So, having some sort of variable resistance on the HV line won't work? ..
    I guess I feel my current backlight does greta in the sun... but now it's just too bright.
    I read a bit on the Scouse thing, but it looked like that project stopped.. I just figured it couldn't be that ahrd to make an variable ristsance circut based on light input ... I'll see what I can do via google.. I had jsut wondered if anyone else had done this already.
    Shawn
  1. Hardware based players (Not PC based)
    By andrewc in forum Newbie
    Last Post: 05-31-2005, 03:36 PM
  2. Projecting through an LCD screen!
    By Shotty in forum LCD/Display
    Last Post: 05-23-2005, 10:57 PM
  3. Replies: 4
    Last Post: 02-01-2005, 01:46 PM
  4. Replies: 6
    Last Post: 10-20-2004, 03:30 AM
  5. Character LCD Based projects
    By CrazyLittle in forum Software & Software Development
    Last Post: 01-20-2003, 07:14 PM
