Results 1 to 6 of 6
Thread: how to keep lilliput touch panel from braking?
    Constant Bitrate fasternfaster's Avatar
    Aug 2004
    Montgomery Co. MD
    how to keep lilliput touch panel from breaking?
    I am on my 3rd Touch Panel now as the first 2 i owned have both broken ( right side "half circle " where you cant calibrate it properly)
    Does any one know what the CAUSE of the problem is and what can be done to prevent it? I am sick of this happening.
    Status: 99%
    hardware: 7"lilli mx440 pci,M10k/160GB/slim-slot DVD-CDRW/Hifonics ZEUS ZX8000,CNX1260,DConnex GPS,Powermate,usb WiFi
    software: XP Home/Media Car/RoadRunner/IGuidance 2.0
    Car: 2002 Ford Focus SVT
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Buy a xenarc?
    Elsewhere
    Lilliputs have brakes?
    Disc or drum?
    How about the Wiki?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    DP you *****!
    buy a decnet screen. digitalww sells replacment panels which should be better than the lilliput one.
    Aug 2004
    Montgomery Co. MD
    from what i gather they are the exact same panel. and are not any different. So what is actualy causing for the touch panel to break? Is it a manufacturing defect? is it exessive pressure? Vibration? Heat? Moisture? Why does it ALWAYS happen on the same exact side for everyone?
    To all of you who say xenarc... please stay out of this thread.
    Status: 99%
    Elsewhere
    In all seriousness, I seem to recall someone who had a similar problem with the touchpanel that was being caused by too much pressure on one side or one corner of the display as a result of the way the screen was mounted. It was molded into the dash, IIRC.
    Also, Lilliputs are notorious for having flaky touchpanels. I'm certain that's the basis for many users screaming "Xenarc!" at you.
    How about the Wiki?
  1. FS 7" Touch Screen Panel + TS Controller
    By mi800 in forum Classified Archive
    Last Post: 04-29-2006, 08:46 AM
  2. Problems with new lilliput touch screen panel?
    By markc04 in forum LCD/Display
    Last Post: 08-27-2004, 01:38 PM
  3. New Lilliput Touch Panel install have question
    By PHiLiSO in forum LCD/Display
    Last Post: 08-04-2004, 02:18 AM
  4. WTB lilliput control panel &...
    By Tha Hombre in forum Classified Archive
    Last Post: 05-09-2004, 06:31 PM
  5. GROUP BUY: Lilliput TM-701VGT LCD
    By krystar in forum Classified Archive
    Last Post: 01-16-2004, 06:31 PM
