Use meters to verify match wires. If you use color code to match wires, you will be screw. Worst case, you fried the screen.
Hi. I managed to get the whole carputer in a gutted donor radio, so I was left with several extra feet of unnecessary Lilli cable. So, I thought, I'll just clip the cable and solder everything back together. Well my first try didn't work, so I guess I'm just lousy at soldering.
Before I cut into it for a do-over, would it be better just to do away with the din connection and go to a one piece cable? Anything to look out for?
Also, do I really need the choke on the VGA cable? If not, I can lose even more cable length.
Mike
1998 Volvo V70 R AWD
2.3L Turbo @ 17psi, 20% Tint
SP-13000, 7" Lilli, Opus 120, 120GB SATA, Holux GR-213, Headrest LCDs
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
