Results 1 to 8 of 8
Thread: Installation question
    Dec 2005
    Santa Cruz, CA
    I just bought a double-din installation kit for my 2000 Celica GT. I am going to install a carputer and hook up the audio into the AUX-IN of my head unit. Excuse my ignorance, but the double-din has one regular slot and a much smaller slot with a pocket. Will the in-dash TFTs go into the smaller slot? Am I missing something? It appears that I have to have the pocket in because the mounting brackets hook into it. I've tried a bit of searching, but I'm new to this forum and my search couldn't find it.
    Elsewhere
    Double-DIN means two DIN spaces.
    Don't use the installation kit. The two single-DIN units will fit in the space on top of each other.
    How about the Wiki?
    Dec 2005
    Santa Cruz, CA
    Now I'm even more confused....
    Dec 2005
    There are very narrow indash monitors that go in a 1/2 din space, but they are few and far between. Most ALL of them are a full din size. If you have a double din space you can put in two din units of whatever you want. Still confused?
    Low Bitrate Daley's Avatar
    Oct 2005
    H-Town
    Toyota's typically have a DIN-sized HU and a DIN-sized pocket below, resulting in a double-din opening. Both of these units bolt to silver brackets (one on each side) which bolt to the dash. If you intend to keep an existing HU and aux-in to it, you'll want something that can replace that din-sized pocket below. Many options are available, just look around. Hope this helps.
    To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
    If it's not fun, you're not doing it right!
    Dec 2005
    Santa Cruz, CA
    Quote Originally Posted by Daley
    Thanks....it does. I am replacing the original CD player with my own, and I bought what was supposed to be a double-din kit from Fry's. The hole/pocket below the regular sized hole on this kit is too small for a regular HU to fit into it. It's not near half, just too small. I guess I'll just have to look for another kit. Any suggestions on where to shop for such a kit?
    Elsewhere
    See, that's what you're missing.... You don't need a kit at all. The two single-DIN units will fill up the enter double-DIN space. The whole point of the kit you did putchase was to cover up the gaping hole that is left when you put a single-DIN headunit into a double-DIN space.
    The only thing you may want is some sort of trim ring to make the space around the two units look a little nicer.
    How about the Wiki?
    Dec 2005
    Santa Cruz, CA
    Ahh ok. But will they be secure? I guess I'll just have to get a screen and find out. I can use the kits trim and just cut out the divider. Thanks a lot guys.
  1. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  2. Replies: 9
    Last Post: 03-31-2005, 03:40 AM
  3. Where to get power inverters? Other question...
    By aquavita in forum Power Supplies
    Last Post: 03-27-2005, 12:13 PM
  4. Xenarc, installation question..
    By Mtlca401 in forum LCD/Display
    Last Post: 05-15-2003, 12:09 AM
