Results 1 to 7 of 7
Thread: Lilliput 7" (629) problems
    Nov 2005
    Hi,
    I have a Lilliput 7" touchscreen (629 model, 2005) and it recently decided it wanted to die. The monitor now does not display any picture. The buttons light up normally, but nothing is displayed on the LCD. This includes the menu, and the green text which would indicate source.
    My question is, has anyone here ever experienced a problem like this and know how to fix it? Or, does someone here have a schematic for this monitor so I can attempt to fix it, or have it fixed professionally for me?
    Any help would be greatly appreciated.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by SirNemesis
    Hi,
    have you opened the case (before it died)?
    Nov 2005
    Unfortunately I have. It was removed from the case to test fit in my car, then put back in the case and tested. It was working corrected for about 2 hours, then I disconnected it and didn't touch it again for about a week. When I plugged it in again, nothing displayed on the screen.
    This monitor has only been used for about 8 hours total, and I have no idea what killed it.
    Alpine CDA-7998R & PXA-H700
    Diamond D7152 : Infinity PERFECT 6.1
    Phass AP4.65i : A/D/S Classic 315i
    Caliber CA2000D+ : RE XXX 12"
    Lilliput 7" Touchscreen
    EPIA SP-13000
    512mb Seitec DDR400
    80GB Samsung 2.5"
    HDA X-Mystique 7.1 Gold
    Morex 80w PSU
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    this is a pretty common problem!
    the 'wireing' inside the lilliput screens is Very fragile.
    these are plastic "ribbon" cables with the wiring itself actually printed onto the plastic with a conductive material. it is very easy to scratch this stuff, wich destroys the cable and requires a replacement.
    Thankfully, what is much more often the case, is that the problem actually occurs at the point that the ribbon cable actually connects to the components inside. sometimes when these cables get bumped, jostled, pulled etc.. they move a little in the connector and lose proper contact of all the many tiny pins inside.
    these connectors are Very BRITTLE, and extremely delicate so you MUST exercise caution when manipulating them.
    that being said, try checking all of these connections for a proper fit, and you may want to reseat them on at a time until you can get your unit to behave as intended..
    GOOD LUCK.
    Nov 2005
    Yes i thought thats what the problem would be aswell. However it is not. I have checked every pin on the cables with a multimeter to confirm nothing is broken. I have also confirmed that they are making contact in the plugs correctly.
    The problem with this monitor is much more complicated then that. Thanks for the suggestion though.
    EPIA SP-13000
    512mb Seitec DDR400
    80GB Samsung 2.5"
    Morex 80w PSU
    Fusion Brain Creator
    Mar 2005
    is the screen white or black?
    Aug 2005
    Lewiston, Maine
    I took some time today and spliced that cable like I said I would.
    surprised that it went in without a hitch but I still cant do 800x480..
  1. Lilliput 7" (first model) touch function dead
    By holistic in forum LCD/Display
    Last Post: 09-28-2005, 02:27 AM
  2. Lilliput Touchscreen Problems
    By Gavc in forum LCD/Display
    Last Post: 06-27-2005, 09:41 PM
  3. FS: 7" Lilliput w/ TS and CNX-P1260
    By brandon in forum Classified Archive
    Last Post: 09-19-2004, 11:39 PM
  4. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 08:46 AM
  5. Lilliput problems (yet some more)
    By samc in forum LCD/Display
    Last Post: 05-06-2004, 10:51 AM
