Results 1 to 4 of 4
Thread: Installing LINITX 8" TS
    Nov 2005
    Nottingham UK
    Hi All,
    I've just put my 1st system together and I'm trying to install my new LINITX TS but just can't seem to get the TS Side of things working ...
    ...the instructions are fairly vague but I've followed all the installer steps but the config utility just doesn't seem to recognise the TS. (although the monitor side of life is fine!)
    In device manager, everything seems to be working ok so I'm stumped ... does anyone have a list of things I should check?
    Your help much appreciated
    Cliff
    Constant Bitrate Paul C's Avatar
    May 2004
    West Sussex
    did you install the drivers BEFORE pluging in the USB for the touch screen?
    Nov 2005
    Nottingham UK
    Yes Paul I did ....
    Ok - so I've fiddled about with this and it does technically work. I say technically because the TS function works but the config utility refuses to recognise the TS (it scans all available com ports and find nothing)
    I've managed to configure the TS through device manager so I'm not so fussed now ... still annoying though that the intended config util doesn't work! ...
    May 2004
    West Sussex
    What speed USB ports are you using?
    I asked about the drivers thing cos thats what I did (it was late and i was excited to play with my screen) and no matter how I tried the screen wouldn't pick up on that USB port, pluged it into another port and it was fine. Perhaps you could try another port and make it install it's self again.
  1. Peugeot 206 GLX - LinITX 8" & Dell Laptop
    By Engram in forum Show off your project
    Last Post: 12-18-2005, 06:25 AM
  2. Installing Linux w/ Lilliput 8" Touchscreen LCD
    By DJBigShow in forum LCD/Display
    Last Post: 12-08-2005, 07:17 AM
  3. Linitx 8" lcd panel size ?
    By MagikTriX in forum Newbie
    Last Post: 09-29-2005, 07:18 PM
  4. LinITX 8"
    By chutz in forum LCD/Display
    Last Post: 03-26-2005, 04:30 PM
  5. LinITX 8" anyone?
    By Gredd in forum LCD/Display
    Last Post: 01-22-2005, 07:44 AM
