Results 1 to 3 of 3
Thread: No image on Lilliput
    Aug 2005
    Hello
    First of all my system specs
    Lilliput 629 with 15ft extension cable
    Via Epia SP 13000
    512 Mb DDR Ram
    Maxtor 120 Gb (formatted)
    Belkin 125 Mbps wifi card
    USB 2.0 Hub
    Opus 120w
    Here is the problem
    I connected everything and powered the hub and the lilliput of the opus. When i start the computer everything gets power incl the lilliput but when i push the power button on the lilliput i first get vga signal and after that a little box with no vga signal when i directly on the mobo it's the same. with the tft from inside the house i get the same. Pretty ****ty because i can't see the boot screen and install windows on the disc
    Anyone with ideas
    Tnx a lot
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    bad vga output?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    have you tried different memory? have you tried a normal PSU? Try running just the motherboard without any drives attached, maybe you have the HD cable on backwards. Also check the cmos clear jumper to make sure it's not set to clear.
    肚子笑痛了
    S60 Install
  1. Lilliput no image
    By linzhang in forum LCD/Display
    Last Post: 11-02-2004, 09:02 AM
  2. not a good image on my lilliput
    By mmoeha in forum LCD/Display
    Last Post: 07-05-2004, 05:25 PM
  3. Lilliput reverse image?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 02:14 AM
  4. Lilliput mirror image feature.
    By Dluvr22 in forum LCD/Display
    Last Post: 03-09-2004, 05:42 AM
  5. lilliput problem-no image.
    By sham in forum LCD/Display
    Last Post: 01-14-2004, 01:13 PM
