better pics of the wire ends would help
Hello Everyone!!! New to Mp3Car. couple months ago picked up some VST 7" LCD Screens.
now that I am going to get around to installing them I need a little help on how to install them. I have a pioneer AVIC-505 NAV System that I also need to install but the LCD cable that runs from the Nav System is an RGB Cable.
I am not sure that the LCD Scrrens I have will work, if not I will use them for a DVD player. In anycase i still dont have a clue on what the wires go to on the LCD screen's, I have a feeling im missing something, for the screens.
Heres a pic.
now on one there is only two wires, and on the other one theres Two wires with a red and white connection coming out (See Pic).
Hope I didnt confuse anyone LOL Any suggestions?
there you go!
if you need closer let me know.
Thanks in Advanced
I can only find this about vst monitors and they look similar, if so you are missing the connector blocks shown in pic below
Lilliput 8" Touchscreen LCD
VIA EPIA MII-12000
60GB 3.5" Hard Drive 5400
512MB DDR PC2700
DVD Drive
802.11G Internal Wireless Card - External 5db Antenna
100m USB Bluetooth Adapter
Nokia N70 Phone
GPS USB Receiver
Centrafuse 1.6
red is hot (12v+)Originally Posted by btnhtillidie
black is ground.
other side: missing rca female connector.
outer part is ground, inner core is signal.
chop an old connector from a patch cable, and solder away.
the units you have are video input only, not vga. won't connect directly to a computer, unless you are using tv out.
good luck
Thats what I figured, now what does the other one only have two wires? and no red or black?
Also for the nav system is there a converter I can buy? Its a Pioneer RGB cable and as you can see the Moniters dont have a RGB hook up.
if not i guess i will have to find the orginal moniter for the nav system.
Thanks Again guys.
the one with 2 wires may be missing the second power feed. So, it may be hot, or ground. the other is probably a small diameter rca cable.
doubtful on finding a suitable controller to use w/ the nav system. pioneer probably made the system propriatary anyway.
good luck
