Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Tester Needed! Lilliput White Screen of Death
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Hey Everyone,
    I know here and there some people here have had the problem on the lilliput where you get the white screen of death because the controller on the back of the LCD panel goes bad. Well I think I might have found the part that causes it. But the problem is I don't have any to test right now. So I need someone that has a LCD panel with that problem and can solder. I need them to try soldering a small jumper to see if that fixes the problem.
    Here is the part that needs to be jumped
    up close
    肚子笑痛了
    S60 Install
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    I would not recommend jumping that circuit. There was a resistor there, and it appears to be fried. By placing a jumper wire there, you may actually change the resistance in that line, and could create more problems. Of course, it could also work too. Who knows, but I doubt you will correct the problem by using a wire to bypass the original resistor.
    Just my 2.6 cents worth.
    May 2003
    Miami, FL
    Oh I understand, but the way I see it is that the LCD is roasted already. So why not try.
    When I measured the resistance of that part in mine it reads as 0ohms. So i'm not exactly sure that it's a resistor.
    肚子笑痛了
    S60 Install
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by jcdillin
    could be something used to jump a trace
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    dosnt work... just tried it
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    what do you guys use to get those tyny screws out? i cant seem to get anything in there
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    May 2003
    Miami, FL
    Quote Originally Posted by xdjxklusivex
    ok, was a nice thought.
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Quote Originally Posted by WebDog
    I just use a jewelers screwdriver
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Well if anyone else can please try it, I least want to have one or two other people try it. Just in case.
    肚子笑痛了
    S60 Install
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    keep working on this... i might have some spare parts to try
    Hey JCD... get on yahoo dude
  1. Lilliput with permanent white screen of death
    By Pale Rider in forum LCD/Display
    Last Post: 01-10-2009, 03:15 PM
  2. Lilliput 8" XGA Touch screen
    By Punisher in forum LCD/Display
    Last Post: 05-19-2006, 07:00 PM
  3. Lilliput screen inside motorized unit?
    By JayKaye in forum LCD/Display
    Last Post: 09-29-2004, 02:14 PM
  4. Replies: 4
    Last Post: 09-01-2004, 02:02 AM
  5. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
