Results 1 to 8 of 8
Thread: Power consumption of a xenarc? good ways to power it remotely/small battery pack?
    Constant Bitrate rotarypower101's Avatar
    Oct 2004
    Portland/MtHood Oregon
    What is the power consumption of a xenarc? And is there any good ways to power it remotely or by batteries in a (non car) enviorment?
    The power supply says that it is a 15W supply, but what do they actually draw? I read a thread that said 8W – 9W, does someone have a solid number from actual tests?
    Are there any solutions to have a remote battery pack capable of powering the screen for a reasonable amount of time that is a fairly cheap solution?
    Just wondering as I responded to a post about a ipod video connected to a xenarc, and was wondering if anyone had done this for a larger portable screen solution?
    Since this is only for video, what would be a low power consumption screen solution that was not a touch screen or even vga resolution, as it really wouldn’t need it for this application I would think, and it is only composite/RCAs out?
    Any cheap ebay solutions that are not going to fall apart in your hands first use, and are low/very low power consumption and at least comparable to the brightness of a xenarc?
    Any ideas or thoughts?
    Tainted Love Cris's Avatar
    Romania
    The screen draws around 8 or 9W. The TS is powered through the USB port.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by rotarypower101
    HUH. WHat are you trying to accomplish?
    The Xenarc, and most montiros will draw about 8 or 9 watts. There is no absilute answer to this, since everything that makes up the screen, every resistore, capacitor, diode, etc, is built to a tolerance, generally about 5 percent. So, no two screens are EXACTLY alike. And just because they are built with components that are 5 percent tolerance, don't think that the power consumption will sway 5 percent in either direction, because each component can amplify the other.
    So, take it llike this, 8 or 9 watts, which is less then an amp.
    Michael
    Nov 2004
    I would think that a ps1 screen would work better for this type of hack
    Oct 2004
    Not really looking to pin it down to a mW at a certain operating temperature, just wanted to confirm that it was in the 8 ish 9 ish range from someone that has actually physically tested it (hoping that someone had done some research in the area of system consumption) and had actual data.
    Quote Originally Posted by Wiredwrx
    Trying to find out if anyone has ran a small LCD such as the xenarc or other small LCD on a remote battery source such as NiMH?
    And hoping somone had some insight about the topic they could share.
    I have seen some AA size 2700s floating around lately, that would make a smallish light weight pack.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    I have a 700TSV which adds about 900mA to the current draw of my PC when it is turned on. That would be accounting for both the 12V to the screen and 5V for the USB touchpanel. So that would be in the 10 Watt neighborhood.
    I don't think anyone would know what yours will draw based on the info you have given so far. Bigger or brighter screens are going to need more power. What you got?
    ~Jimmy
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Why don't you get a battery powered DVD player and be done with it?
    Want to:
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    Why don't you just buy a factory gps/mp3 unit and be done with it?
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 10:10 AM
  3. Recommendations for a good deep cycle battery?
    By Vchat20 in forum General Hardware Discussion
    Last Post: 09-10-2005, 05:03 AM
  4. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  5. Problem with tank battery - any good Plan B?
    By Mastiff in forum Power Supplies
    Last Post: 06-14-2004, 09:10 PM
