You must have a new modek Lilli. The box (used to be the egg) includes a regulator and a fuse, so no need to put a fuse inline unless you are paranoid. (It can't hurt to have too much protection if you put in another fuse)
The cigarette lighter power should be off when the ignition is switched off. As you said, If the socket provides constant power just put a switch on the Lilli's wiring to turn it off if you want.
LinkBack URL
About LinkBacks
