Results 1 to 8 of 8
Thread: backlight question
    Jan 2005
    backlight question
    i have a simple backlight question how hard is it to replace the backlight in bulb in a screen? as mine has gotten kinda dim
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by yonu
    depends on the panel, and the availability of a replacement ccfl.
    some are as simple as removing a screw, sliding out the cartridge, removing the lamp, and unsolder/resolder the leads.
    Others require a more complex disassembly of the lcd panel to access the lamp.
    Verify that you can get a replacement lamp, as you may in fact be replacing the lcd panel.
    Jan 2005
    ok thank will start looking for tubes and see if it can be replaced just wans't sure
    Jan 2005
    Ok i got it took apart but iI am unsure if i should just strat removing screws or if someone might beable to tell me form the pics
    Jan 2005
    ok and here is a pic of the model number of the lcd panel which i am looking up now
    Apr 2003
    Detroit, MI
    the backlight is replaceable, and is an easy part to get.
    you need to remove the panel from the frame, then remove the ccfl from the panel. post pics please. will advise on ccfl removal if you want.
    Jan 2005
    ok will do now another question where do I get the tubes from
    Apr 2003
    Detroit, MI
    www.mouser.com, or www.digikey.com.
    ccfl lamps are measured in mm, both diameter and length. do not count the wire leads when measuring the length.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. Question about Xenarc screen
    By Obsolete in forum LCD/Display
    Last Post: 05-25-2005, 11:41 AM
  4. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  5. Inverter question in regard to backlights
    By osirisdon in forum General Hardware Discussion
    Last Post: 04-04-2003, 09:25 AM
