Results 1 to 9 of 9
Thread: 3 din / verticle monitor
    Feb 2006
    West L.A.
    Question 3 din / verticle monitor
    I have been searching the web for a 3 din monitor. Does such a thing exist?
    I am just starting to get into the carputer thing, but I feel confident I could move or use some other control device for my climate control (I would love the computer to eventually do it, I think I've seen some people pull that off).
    So the desired effect would be a portrait-oriented monitor that looks like it had to be stuffed into my dash. I would like it to be a touch monitor, too, but that's secondary to the size. Everything I see seems to be meant to fit landscape-wise, and the sizes jump from 8" to 10.4" to 14". Am I the only one that thinks mounting a monitor vertically would be AWSOME?
    -Blaze
    "Live if you can, die if you must, but always fight with honor."
    "There is NO way that should have worked!" -Sahara
    (O:o)===W===(o:O)
    =====[XLR8]=====
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    May 2005
    Rochester, NH
    although not completely perfect 3 din... the 8" or 8.4 I think fits almost perfectly in a 3 din opening... I am hoping to do this with my 8.4 that I'm building right now with the backlight upgrade... there is a guy that did this...
    and ended up with this...
    You can check him out here...
    2000 Mitsubishi Eclipse with 8" LCD, Relocated Stereo & AC Controls
    Feb 2006
    West L.A.
    SWEET! thanks! so now comes the inevitable question, can it be done as a touch screen? If I remember correctly, the tablet PCs are specifically designed to take input only from the stylus. Are there touch adapters for any size screen including widescreen laptops like that one?
    -Blaze
    (O:o)===W===(o:O)
    =====[XLR8]=====
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Quote Originally Posted by ceBlaze
    The screen in the pictures dmcdlrn posted is a touchscreen monitor.... he says it's a Lilliput 809GL in the thread.
    (if you are referring to freelander's link then disregard this)
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    May 2005
    Rochester, NH
    second that... its a touch screen... so is my 8.4. You can do a touch screen for just about anything without any more space really... touch panels themselves are only about an 1/8" thick and are supposed to be the same size as the screen size... then you have a small controller board and ribbon cable...
    Feb 2006
    West L.A.
    yeah, actually i was referring to freelander's link. I may end up using an 8" because I don't want to modify much more than the hard plastic din slots, certaily not as drasticly as that mini-van, but I love how the screen in that one has almost no bezel around it. I really want it to look like it's the biggest thing i could possibly cram in.
    (O:o)===W===(o:O)
    =====[XLR8]=====
    Feb 2006
    West L.A.
    also, i heard once that building up a laptop isn't all that much harder than building up a desktop. anyone have any good links?
    (O:o)===W===(o:O)
    =====[XLR8]=====
    May 2005
    Rochester, NH
    I run a laptop. I don't know which is easier... laptop is much more compact though..
    I am revamping and using a docking station this year so I can use the laptop's internal sound card... the docking station has a pci slot plus space under it to stick my fm tuner... and usb is all I need for devices... Normally you can buy a stock dc to dc for your machine thats designed to work... also designed to create less heat and consume less power.. plus it has a battery allready built in so it will last a crank...
    downside is they are more expensive and less available typically, also less versitile normally cause of no pci slots.
    But, you have to read and make up your own mind... I chose laptop and I think it was the right choice for ME... good luck!
  1. Double din VGA monitor
    By afarre in forum LCD/Display
    Last Post: 11-01-2010, 12:56 PM
  2. Best monitor for Double Din?
    By sanbas in forum LCD/Display
    Last Post: 11-19-2006, 05:58 PM
  3. Replies: 1
    Last Post: 12-31-2005, 02:48 AM
  4. ForSale: InDash (DIN) 7 inch SVGA LCD Slideout Monitor
    By guardianzx9 in forum Classified Archive
    Last Post: 01-25-2005, 08:11 PM
