use a single scrap pc. of wire, feed it through, then tape it around the bulk of wires you are trying to pull. You could also use decent test fishing line. I am assuming of course that you can feed a single wire without issues. The bend in the arm may be too tight to feed a lot of wires. Sounds like quite a project you have. You may also consider using a smaller diameter vga cable, chop the ends, and feed it through. Then, simply make your connections.
LinkBack URL
About LinkBacks
