Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Sharp/ Casio Gamecube display
    Feb 2006
    Thought I'd post here first as your forum's led me to the information I needed to complete this hack.
    I recently hacked a Sharp LM6Q401 display (Identical to the Casio CMV54NT04P)
    for VGA input. Here's how I did it.
    1. Get a game-cube portable display such as the Interact brand one I used, basically anything containing the LM6Q401 or CMV54NT04P display module.
    2. Dissassemble until all you have is the bare display
    3. Get a VGA cable or connector and wire it up
    Back of LCD:
    1 - NC
    2 - Blue
    3 - Red
    4 - +12v
    5 - Gnd
    6 - NC
    7 - Composite Sync
    8 - Green
    9 - +12v
    10 - Gnd
    DB15 or VGA connector:
    1 - Red
    2 - Green
    3 - Blue
    13 - Horizontal Sync (connect to composite sync)
    10 - Gnd
    4. Make a connector for the back if you like
    I used the power connector from the origonal casing and a cable cut from the back of a dead monitor
    5. Hook it up to your computer and configure it with powerstrip. These are the current settings I'm using:
    640x480 (arcade mode setting)
    Composite Sync (this is the key to making it work)
    Interlaced
    Pixel Clock: 11Mhz
    Horiz Scan rate: 13.221Khz
    Vert Refresh rate: 20.498
    you'll have to play with the size/ position to get it dialed in perfectly
    6. Enjoy the end result
    Mar 2006
    any ideas , powerstrip
    first i would like to say that the infomation above has provide a lot of help cheers for posting it.
    i have got the sharp display (gamecube lcd ) exact same display, wired up corect as per the prevous post.
    the display defently does works properly as i have tested it.
    the problem comes when configering powerstrip . i can get get at display at 640 , 480 this ok but its it will only be in the centre of the screen . so the image is square and a strip aprox 1cm vertical either side of the display that is wasted. AND is too small really.
    i have tried adusting the timing and sizing and but when i incease the size past what will fit on the display the display goes out of sync.
    i also can only get the stanard res working , 680 by 480 , 800 by 600. ect
    the aspect radios dont do much either.
    any help or things to try would be a great help.
    thanks
    Feb 2006
    To get things sized up properly I had to do alot of playing with the settings (Fields such as: front porch, etc...). Wish you would have posted before I reformatted, could have put up my config file...
    Mar 2006
    thanks for your reply ,
    much aprecied . will have to play about more .
    if anyone has any more info please post .
    Mar 2006
    it works .
    just to say that i have got it working not too bad and it fills the whole screen. ended up buying a cheep and old
    Matrox Mystique PCI Graphics card off ebay and now it works.
    Apr 2006
    Thanks for the guide, much appreciated!
    Just wondering though, how do i find out which wires inside the VGA cable go to which pins on the cable?
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by dazmanultra
    Am I reading this right??? Did you just ask how to tell which wires are attached to what pins on a chopped VGA cable?
    Ever hear of an Ohm Meter? wtf? if you are entertaining the idea of doing this VERY simple hack, and don't have a dvom, or know how to trace wires on a cable, please disconnect from the internet and go outside to play.
    Thank you.
    EDIT: props to the OP for a well written, detailed how to. Good job newbie!
    Apr 2006
    Quote Originally Posted by Motorcity
    Thank you.
    No need for the rudeness mate, especially not to a new member... I thought there might be a standard, like with a CAT5. Just saves me (and everyone else) a few minutes messing around with a multimeter.
    Apr 2003
    Detroit, MI
    There is no color standard that I am aware of when it comes to VGA cables.
    If there is, I think ISO's website would have that info.
    Sep 2006
    Hey, anyone have the pinout to the controller board for the sharp gamecube screen. the origanal one?
  1. Sharp LCD display
    By Endo in forum LCD/Display
    Last Post: 07-22-2005, 01:38 PM
  2. Sharp display for trade
    By ttlinux in forum LCD/Display
    Last Post: 11-18-2003, 11:13 AM
  3. Datasheet for Sharp LM64C151 TFT Display
    By gnarf90 in forum LCD/Display
    Last Post: 04-20-2002, 01:53 PM
  4. Pinouts for Sharp display.....
    By BootySlap in forum LCD/Display
    Last Post: 05-08-2001, 07:49 PM
  5. Sharp LCD display
    By ImpoSSter in forum General Hardware Discussion
    Last Post: 11-14-2000, 10:49 PM
