This problem was fixed by installing new touchkit drivers
I have my new truckputer installed and I'm leaving Friday and I will have 25 hours of driving.
Most everything is working well except for one oddity. If the touch screen isn't used (you don't put a finger to the screen) for awhile the touch screen stops working. The only way to fix it is to unplug the USB connection from the PC and plug it back in. This would be impossible while driving. Turning the monitor off and on results in the windows logo staying on the monitor and I haven't been able to figure out the hot key for the monitor to clear it and return to windows.
I don't see anything under Windows XP "Power saving" or in the motherboard bios that would account for this problem with the touch screen.
Has anyone else run into it and how was it solved?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
we heard you the first time
