Have you tried tap and hold?
I removed the software that came with my Lilli touch screen and I downloaded and installed the new touchkit software from the Lilli web site.
Does anyone know how to simulate a right click? For example, lets say I want to get the properties on something. How do I right click using the touchscreen?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
I've tried placing my finger on the icon and holding, but properties doesn't come up
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
maybe u didn't set the right clik on, try using a mouse to turn the right clik on, i duno what i'm saying , but good luck
Progress Bar: [//////////]100%
Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
all fabrication done...
Hmm....well if its anything similar to the touchkit program that came with my monitor there should be a small mouse icon in taskbar that you can click to switch between left and right clicking.
You sure you set the correct settings in the touchkit software?
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
It would be nice if it had that little dotted circle thing that PocketPC has for holding to right click.
There is supposed to be the little icon in the bottom left to change to right click. I'm pretty sure the new software came with that as well, but you have to turn it on in the software.
The original Worcol software had a deal where it would display an icon with a left and right button but I uninstalled that software when I installed the new touchkit. I'll look throught touchkit and see if I find a setting somewhere to turn on the icon you talked about.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
I found a setting to enable auto right click. I turned it on but haven't walked out to the truck yet to see if that fixed it. I'm working on the truck PC, from inside the house, using PCAnywhere. *GRIN
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
