What changed ?
I would think the Power Supply and you moved the system.
Start by checking all the connections that you removed and re-connected.
Also make sure the power supply is working. If you are using an inverter or a DC to DC solution, replace it with a desktop supply you know works and use an extension cord to house power.
This will tell you if it is a power issue or a connecter issue (this type of issue is common) If those changes do not get results you will need to post detailed specs of your set up. (hardware and software)
Good luck
LinkBack URL
About LinkBacks
