check out this link
http://www.elephantstaircase.com/wik...CAT5conversion
I got a hold of a LCD screen off of a store display for some childrens game council. Anyway the video in cable is a network cable. Is there anyway to convert this to a RCA video cable? Thanks for the help.
check out this link
STATUS: Planning / In Progress / Completed
COMPLETE: [*********] 100%
CAR: '02 Mitsubishi Lancer OZ Rally
SYSTEM: EPIA M10000
GPS: HaiCOMM 303e GPS, Routis 2004
DISPLAY: 7" Xenarc 700TSV
POWER: OPUS PW-70a + ITPS Combo
MISC: DVD, WLAN
If i would only use two of the wires coming out of the screen what are all the other ones for, b/c they are all connected to the circuit board on this thing. Ill post some pics
Originally Posted by cpjolicoeur
wrong
it's a whole lot more complicated than that, and you likely won't be doing it without the datasheet
not sure what you are talking about, but i've used this method to extend video cables before. I use these converter boxes to run the video across a CAT-5 cable across my house. never had a problem with it.Originally Posted by greenman100
SYSTEM: EPIA M10000
MISC: DVD, WLAN
if this is any help here are pics
Yeah, without some sort of data sheet, can't really tell you much.
i agree you will probably need to see some specs from the screen. my link was simply how to convert RCA cables into RJ45. you can probably do this for the video, but I'm not sure what lines on your board are for audio/touchscreen/etc...
SYSTEM: EPIA M10000
MISC: DVD, WLAN
extending composite video on RJ-45 is simple
assuming that his RJ-45 connector is composite standard signaling is one heck of an assumption
you are correct. i stand corrected. I guess I didn't read his question fully before I posted the link.Originally Posted by greenman100
I am in no way saying you should mess with the other wiring until you know what they are. don't take anything for granted at the risk of damaging the display.
SYSTEM: EPIA M10000
MISC: DVD, WLAN
