Results 1 to 3 of 3
Thread: Identifying Cables for Video, Audio & Power
    FLAC ukchris's Avatar
    Nov 2003
    Okay, I have this DVD player and Composite screen. The DVD Player takes 12 volts then has an 8-pin S-Video "style" cable that runs to the screen. That cable carries power, video and audio to the screen. The screen then has a pair of RCA connectors for left/right audio coming out of it.
    So, I need to know which pin is which so I can use the DVD player with a different screen.
    With a multimeter I have found a couple of grounds, one pin showing 12v and another 2v but that's about it. My question(s) therefore is... how can I safely identify what wire is doing what?
    I have tested for continuity from the speaker cables backwards and found the outer RCA connector must be ground as it is shared, both connect to two pins in the cable. I get no continuity from the inner connector though although there is a volume control on the screen, would that affect testing for continuity?
    How can I detect a video signal using a mulimeter?
    How can I detect an audio signal using a multimeter?
    If I can't how should I experiment with hooking it up without blowing anything... heh..!
    Any help MUCH appreciated!
    Nov 2003
    Here is a rough sketch of what is going on so far...
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    maybe a breakout cable??
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:28 AM
  2. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  3. Power cables, where to get cheap.
    By WebDog in forum Car Audio
    Last Post: 04-06-2005, 04:42 AM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 10:31 AM
  5. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 12:08 AM
