ATI Graphics Card Tv Out
Hello,
Im after building a small setup which would use a 5" screen in my dash. Would i be able to connect the display straight to my ATI Rage Graphics Card TV Out or would i need some other stuff.
Thanks for your time,
Mav,
probably need to setup at least a 75ohm reistance on the line. That is unless your screen will give the 75 ohm resistance so your ati card will pick it up
It really depends on your LCD. If you purchased an LCD that was prefabbed for a car (pyle, lanzar, mobile, etc) you should be able to use your tv out from your video card and run it directly to the LCD.
If you are building your own LCD/inverter/conversion, you will probably have to use a resistor.
BMW Spead Freak
My Install
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
