power support????
power supply?
you are best powering the screen off your PC power supply anyway as those lighter adapters are generally crap. Alternatively, look for a regulated dc-dc psu with 12V out. and don't get the polarity wrong or boom!
I have lost my power support for a car adaptor for my Lilliput 619, is there an orginal or compatible solution?
power support????
power supply?
yeh meant supply..
what one will i need ?
well something that gives 12V out, regulated and at leat 1A.
http://www.carcomputer.co.uk/touchsc...php?product=56
would that be compatible ?
good greif mate, are you really building a carPC?
I have never seen that company before, or the adapter but by the looks of it - from the sticker on the front it is likely (12V out). If it is in the touch screen section than it is more than likely. As they seem to only sell lilliput screens then even more likely.
did you email them to check?
There is no power rating but i imagine it is capable of a measly 10W as it is in the screen section and the only other issue would be the plug size and it's polarity.
Why dont you just hook your screen up to your computer PSU? I dont like those little power regs.
Originally Posted by World705
That's the dreaded Lilliput Egg![]()
in that case dont bother. run it off yur psu. there is a sticky about it in the LCD section.Originally Posted by Enforcer
EDIT: didnt they make it better? or is it still cr@p?
EDIT2: cos they kept frying!
Originally Posted by Scouse Monkey
I used to use them but since my second went tits up I have been using something else, will see if I can find a link
already built.. and customised..good greif mate, are you really building a carPC?
only lost the power cable to monitor.. i've done all install including flushing in to console etc.
