Results 1 to 10 of 17
Thread: Question about lilliput. Can i extend these wires?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i need to extend these wires cause i need to lay the controller flat (thanks to the stupid 8" bottom connector. Any problems with me just cutting them and adding a lil 12ga. wire? I'd only need about 6" or so. I just dont want to cut the wires and find out there like rca or some funky wire.
    Live mp3Car Facebook Chat
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    yes, there is a big problem! those are AC Voltage wires, not standard wire.
    you need to use the correct wire type, and splices need to be soldered and covered with UL approved heat shrink, or electrical tape.
    If you have an old lcd panel laying around, scavange the wire from the backlight.
    otherwise, I highly recommend you purchase the correct supplies needed to extend those wires.
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Motorcity
    Ok, what is the correct wire type exactly?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    wow if u mess up ur gonna get fryed lol
    Woodbridge, VA
    Blog Entries
    55
    lol i assume if i unplug the thing i'll survive.. All it is is 12 volts right
    Apr 2003
    Detroit, MI
    Quote Originally Posted by Sonicxtacy02
    wrong. try 800+ volts...AC
    Apr 2003
    Detroit, MI
    http://www.mouser.com/index.cfm?hand...denumber=56005
    available in white and pink. you can use either or. no need to buy both colors, they are the same AWG.
    use heatshrink tubing, to cover the solder splices.
    this wire is high voltage rated, and is silicone.
    Woodbridge, VA
    Blog Entries
    55
    Thanks for your help. So i purchase this wire. Cut the connectors at the connector solder in these and use heatshrink tubing and we're fine and good? I assume once i've unplugged the lilli from the ac adapter there's no risk of shock right?
    Feb 2006
    listen though 800 v ac ain't no thang, depends all on current. after seeing a guy last week fly 20 feet from touching something with 8v and 200a (no he magically didnt die just blew a hole out the bottom of his boot, i would say no worries.
    all you have to do is get the correct wire it looks like 16 gauge wire to me. wire type only matters when running it long distance due to internal resistance of the wires. Hopefully you know how to solder however if you don't you can call me and i can step you threw setting the temp, using flux, all the shenanigans.
    you should be fine if you make the correct union on the wires and don't get crazy trying to run to high of a current. the best thing i would do is get an amprobe and power it up place it over the wire and take the reading from there, but if money is an issue to buy one then try home depot for a multimeter (15 bucks) and i can step you through testing safely.
    Apr 2003
    Detroit, MI
    Quote Originally Posted by 1BadRbt
    all I can say is, you don't know what the hell you are talking about........
  1. lilliput warranty question
    By SuperFastCVT in forum LCD/Display
    Last Post: 01-29-2006, 06:22 PM
  2. Lilliput Problem, and Replacement Xenarc Question
    By Mrbmw99 in forum LCD/Display
    Last Post: 07-04-2005, 07:08 PM
  3. 8" Lilliput question, extracting sound and screen rolls
    By clean customs in forum LCD/Display
    Last Post: 06-30-2005, 11:10 PM
  4. New Lilliput Touch Panel install have question
    By PHiLiSO in forum LCD/Display
    Last Post: 08-04-2004, 03:18 AM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 12:13 PM
