Every barrel type plug I have seen is ground on the outside and + on the inside.
I have tried searching google for this piece and the only place I have found wanted about $70 after shipping which seems insane. I Also dont think I need the extended version of this cable because the monitor only has to reach to below the seat which should reach fine in my case.
I was also wondering if anybody knew off hand if on the power plug the inside of the barrel was positive or the outside of the barrel. The faq only talks about the ciggerette adapter for this.
I finally ordered a cable and started wiring this thing up. Thanks for the heads up on barrel plugs, I also found the label on the back of case indicates which is which.
We have all kinds of extra parts like that. Give us a call with what you're looking for.
where did u get the cable, i think my cable is not workin...so i would like to get a new one to try before i send it to Xenarc..50+ for a cable is crazyOriginally Posted by Ub312g0d
Does anyone know if there i can buy this cable at a local retailer...it would be 20pin to VGA i guess? Correct?
