Results 1 to 6 of 6
Thread: Problem with LinITX 7" TFT
    NeX
    NeX is offline
    Mar 2006
    Hello all,
    i have a linITX 7" TFT and when i boot the pc and push the power button on the screen to switch to VGA mode the screen shows the pc for about 1 second and then switches off. but if i start the car then the screen stays on...
    does anyone know if the screen has some sort of low voltage shut off?
    is there a fix for this problem?
    thanks ppl
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    no idea. this is an odd one. Could certainly be a voltage issue. try putting a meter accross the power lines to see what voltage you are getting. your battery could be struggling or you could be getting a voltage drop somewhere in the run to the screen. How are you conencting it to the battery?
    Aug 2002
    Eau Claire, Wi
    I have a linITX screen and this happens to me every now and then. It only happens every two or three months or so. For me all i have to do is cut all power to the screen and then re-apply power and it turns on fine. I have never pinpointed the cause, but since it happens so infrequently I didn't look very hard either.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    NeX
    NeX is offline
    Mar 2006
    thanks for the replies,
    i have a set of switches that have a constant 12v supply and a 12v supply that comes on with the ignition. when i switch something on like the PS2 etc the double pole switches send power from either the 12v constant or the 12v acc to the screen and the device that i want to switch on.
    so the screen isn't always connected in the same way each time.
    i'm thinking its a voltage drop because the amps are on and the pc as well as the screen and the HU, i'm just wondering if anyone has had to use a capacitor or a voltage stabiliser to keep things running?
    i'm upgrading to an Optima battery later on and the one i have at the mo is pretty pants, if i leave the headlights on for a few minutes then the car won't start.
    still the screen shouldn't need too much power should it? like i said it does switch on for a second but it's as if it doesn't detect the pc signal and switches off. its never happend when the engine is running....
    Mar 2004
    Bristol
    I doubt a cap will work.
    NeX
    NeX is offline
    Mar 2006
    the other thing is that when the screen is switching itself off there is still plenty of power in the battery to crank the engine.
  1. LinITX 7" Monitor
    By James141 in forum LCD/Display
    Last Post: 03-17-2005, 10:17 AM
  2. Replies: 1
    Last Post: 01-22-2005, 09:03 PM
  3. FS: 7" TFT Video modules (12pcs) - $60 shipped
    By digitalww in forum Classified Archive
    Last Post: 12-28-2004, 11:48 AM
  4. Replies: 0
    Last Post: 06-15-2004, 12:01 AM
