Results 11 to 20 of 22
Thread: 8 inch Widescreen LCD in double Din
  1. #11
    Mar 2006
    Thanks Sama, yes i think i saw this from you other posts.
    Gary
  2. #12
    Mar 2006
    Taken the dash out again today, first impressions are that it will fit with little modification to the console.
    I made up a paper template the exact size of the LCD and test fitted it to the dash. Seems all i have to do is cut out some very small ribs at the bottom of the double din opening to allow the screen to fit flush against the console. A five minute job.
    All i have to work out now is how to mount the PCB of the LCD behind the screen.
    Sama if your reading this, do you recon there is enough lead length on the LCD to allow the PCB to lay 90 deg to the LCD ?
    OH YEA!, time to save some cash for the screen.
    Gary
  3. #13
    Jun 2005
    I found one, made by Provision. looks good.
  4. #14
    Mar 2006
    LInk PLease
    Would it be this one http://www.amamax.com/amamax/prpr8iwvtosc.html
  5. #15
    FLAC sama's Avatar
    Feb 2006
    London, UK
    plenty of length on the ribbons, but you may have to extend the backlight power cables, or maybe not if the center of rotation is around the backlight cables.
  6. #16
    Jun 2005
    Quote Originally Posted by Dimlow_UK
    LInk PLease
    thats the one. I'v seen box pictures of the:
    http://linitx.com/product_info.php?c...roducts_id=877
    same remote as the provision, same specs, same driver CD. It looks like the provision has the buttons at the bottom while the LinTX is at the side. I'm quite positive they are from the same manufacturer.
    I found the provision at a much cheaper price. for about $200usd.
  7. #17
    Mar 2006
    Sama, Thanks for the info, im sure i could lengthen the backlight power cables, but the ribbons could be a little tricky. I will have to see when i get it. Still, im waiting for the funds to materialize now.
    Mojo85 where did you find it for $200 ? All i can find is $299
    Gary
  8. #18
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I'm sure if you focused eveything on the ribbon cable, then the USB and power cables will be easy to extend. just make sure you heatshrink the power extensions 2-3 times. there's a hell of a lot of voltage through those wires. I barely touched the insulated wire when the screen was on and I could feel the electricity. might have something to do that I'm an X-Man (my imagination) but might not be
  9. #19
    Low Bitrate SuprchargdMazda's Avatar
    Mar 2006
    Gary
    Hey, theres 3 of them up on eBay for $210usd right now: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=8789501714
    He only ships to USA only though, I'm guessing the UK in your sn means your in England? If not, thats the best price I've seen...
  10. #20
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you should never splice HV CCFL wires
    and thw wire hould be rated at about 3kV with silicone insulation.
  1. Replies: 18
    Last Post: 08-28-2009, 05:16 PM
  2. Possible Lilliput Double Din Mount?
    By sheerdark in forum Fabrication
    Last Post: 08-06-2007, 11:32 AM
  3. FS: Indash Double Din 6.5" LCD DVD/AM/FM
    By CDesigns in forum Classified Archive
    Last Post: 05-12-2005, 02:18 PM
  4. Replies: 5
    Last Post: 03-31-2005, 02:07 PM
  5. Double Din to Single Din
    By loganm in forum General Hardware Discussion
    Last Post: 03-20-2005, 09:58 PM
