Results 1 to 6 of 6
Thread: K301 vs K90 (vs k500)
    Jun 2004
    Hello
    Since my Xenarc was stollen, I need to by a motorized screen.
    K500 is too new, it's not too preety and it has TV and amp (so we can't use m1atx to power it also, isn't it?!)
    k301 has Hitachi panel with a contrast ratio of 300:1 and nd the screen at the top of encosure
    K90 has Panasonic panel, contrast ratio of 150:1 and the screen at the bottom of encosure (saves space when opened), and also have TV.
    what do you think is better??
    Elsewhere
    The K301 is far brighter than the K90. That's a huge plus.
    But realistically, it's all up to what you think is better, not what the rest of us think is better.
    How about the Wiki?
    May 2005
    PNW
    I'm going for the K301 myself. I like the looks more, and the higher contrast ratio helps. But... it's about $100 more than the K90.
    Jun 2004
    I can get the k300 for 420€, the k301 for 479€, the k500 545€ and the k90 433€.
    what are the diferences between the k300 and k301?
    I've never seen none of them for real, just pictures, that's why i'm so...
    May 2005
    PNW
    I've been e-mailing the manufacturer back and forth for a while now, and here is what she said about the K300 versus the K301:
    K301 and K300 are same in function. K300 is base from K301. K300 's button is lower than K301's on front case. K300 and K301 are also defference on front case design. K300 is more easy for your hand pressing.that is all.
    Glasgow
    was it linda that you talked too?
  1. Feedback K301...
    By FreaQ in forum LCD/Display
    Last Post: 05-29-2006, 02:43 PM
  2. FS: K90 In-dash LCD Touchscreen Monitor
    By jwoznack in forum Classified Archive
    Last Post: 05-14-2006, 04:22 PM
  3. K301 - Problem with Remote output
    By Nils Schneider in forum LCD/Display
    Last Post: 02-11-2006, 01:36 AM
  4. K301 Reverse cam wire
    By keanpedersen in forum LCD/Display
    Last Post: 08-15-2005, 05:53 PM
